well mineral oil doesn't count as "submersible".  PC's aren't "submersible" either and they work just fine in mineral oil ;)
That being said, mineral oil doesn't pump the same as water does since it is thicker.  You won't be able to get great flow rates with any watercooling pump but it will probably get the job done as good as any other.  I haven't researched pumps for mineral oil builds though since I gave that dream up a while ago... thanks for re-sparking it haha
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/623546-mcp35x-pump-question/#findComment-8039535
11 hours ago, Holden_Adamec said:
-SNIP-
It's the same as why can you have the entire PC in the oil, the pump itself is just sitting in lubricant so it will also be actively cooled by it while pumping around the fluid.
https://linustechtips.com/topic/623546-mcp35x-pump-question/#findComment-8040842
18 minutes ago, Holden_Adamec said:
thx
If your going to be making something like this then you should make a build log. Lots of folks would like to see more of things like this
https://linustechtips.com/topic/623546-mcp35x-pump-question/#findComment-8056252
On 9-7-2016 at 8:36 PM, Holden_Adamec said:
The MCP35x pump is a non-submersible pump. In this video the guy uses it in a mineral oil cooled build.
Just wondering if that's a good idea, or if I should look for another pump like a submersible one. If so, any recommendations?
What fans are your using, you didnt hear them at all!  Very intersted now haha
https://linustechtips.com/topic/623546-mcp35x-pump-question/#findComment-8088420
