Is there a motherboard that has: 2x  USB 3.0, 2x USB 3.1  2x  USB 2.0,
If it helps you could just have 6x Usb 3.0 slots and 2x usb 2.0 slots 2x hdmi, Or 1x Hdmi And 1x Dvi,  1x Ethernet, 1x, vga, 2x PS2,  and  Mic, Left and Right speaker ports.
My PC Currently Is The P2-1320a.
https://linustechtips.com/topic/622748-motherboard-help-2/
From your earlier posts I saw you had the 1070 so I'm assuming you're gaming so you don't need all those video ports on your mobo since the video plugs will be into your gpu. The Asus H110M-A has everything you wanted except for what I said above and 2x USB 3.1.
http://bit.ly/29mDY4B
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
https://linustechtips.com/topic/622748-motherboard-help-2/#findComment-8030078
I Need 8 usb slots :(
and if it helps i could just get 6x usb 3.0 Slots and 2x usb 2.0 slots...
https://linustechtips.com/topic/622748-motherboard-help-2/#findComment-8030082
damn. I'll look around for some it may take a little bit..
Ayyyyyy
https://linustechtips.com/topic/622748-motherboard-help-2/#findComment-8030085
Lucky find I geuss, this has everything your original list asks for, its a little pricey at $160 tho.
http://bit.ly/29CW3wV
Ayyyyyy
https://linustechtips.com/topic/622748-motherboard-help-2/#findComment-8030091
Just buy one of these type adapters if you really need more usb slots...
http://www.newegg.com/Product/Product.aspx?item=N82E16815158354
They are like 15-25 dollars on ebay.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/622748-motherboard-help-2/#findComment-8030096
usb hub maybe? You can use up to 50 USB devices lol
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/622748-motherboard-help-2/#findComment-8030098
You can get a USB hub or add-in PCI-E card. What do you need 8 USB slots for?
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/622748-motherboard-help-2/#findComment-8030125
