Hi all -  I'm building in the Define Nano S and decided to use a Corsair SF450 PSU (to work around the GPU clearance issue).
I have a 1tb HDD in the back of the case and I want to put my SSD on display on the case floor, but the PSU only came with one quad SATA power cable. I don't see how I could make that work for both.
Do people usually buy single SATA power cables to use with their SSDs that are "on display?"
https://linustechtips.com/topic/622708-single-sata-power-cable-needed/
yes, I think so
you can find super cheap SATA power extensions on amazon though
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
You could modify the harness to only have one sata power if that's all your need or get something like a sleeved extension so it's the only thing that is seen in the front side of the case.
-Topics Merged-
