I'm going to be putting 2 MSI gaming x 1080's in the 400c, and was planning on getting curved custom extensions from https://mainframecustom.com/ but I was trying to figure out how much room would be between the extended PCB and the glass side panel because I'm trying to figure out if the extensions will be pressed against it, or if I can pull them down and not quite touch the glass. Also I am going to put a cut in the psu shroud for the cables to go through.
Edit: Basically anyone with this case measure the distance between a normal GPU width to the glass in inches, CM, or mm. I can find out how much of that room the gpu takes in spec sheets
Edited by vladonizer
https://linustechtips.com/topic/621291-400c-gpu-power-cord-extensions/
