System specs
CPU- i5 2400
Mobo- gigabyte z67
RAsoon to M- 8 gbs of 1333mhz
GPU- Zotac GTX 560 1 GB
Storage- 1 Tb Hard disk
I am looking to upgrade my system eventually and am unsure on what to add or change in my system. The monitor I currently use is a 1080p asus 60hz gaming monitor and i wish to achieve steady framerates in the 200-300 range on 1080p and ultra on games like csgo and dota. i currently get around 100-150 on low at 800p.
https://linustechtips.com/topic/620998-lga-1155-system-upgrade/
7 minutes ago, generalchunk3rs said:
System specs
CPU- i5 2400
Mobo- gigabyte z67
get an rx480
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/620998-lga-1155-system-upgrade/#findComment-8011330
