So I thought I knew what I was getting a couple of weeks ago, but I feel like I need a little help in what I want in my next PC. Let me share with you what I absolutely need first.
  • Very low temperatures, with minimal sound. More emphasis on the low temperatures though!
  • The least amount of wires inside as possible. I'm looking to utilize M.2 storage, for example.
  • Easy to open, and clean out dust. Easy to handle, and transport. Handles?
  • Would prefer a decent look with window, but not my priority.
  • Just one beefy GPU is all I need. I still don't see the point in a multi GPU setup for me.
  • A motherboard that puts out the best sound, really don't want a separate sound card.
  • Play any game I throw at it in 1080p at maxed out settings. Anyyyyy game.
  • 2 monitor setup eventually, primary being a 27" 2K or 4K 144hz, second being 24" 144hz 1080p.
  • Also need the ability to stream everything I'll play, at those maxed out settings.
  • USB 3 Headers.
So a little about me and how I'll be using this machine. I know it's going to cost multiple thousands of dollars, and that is fine with me. As long as I get what I need. I currently live in an apartment, on the top floor. So when it's 70 degrees fahrenheit outside, it's more like 80something inside my room. Yes, I have an AC, which turns my electric bill from 100 bucks a month, to 300 bucks a month. So, that's why I usually don't use it all the time. And thus my PC gets toasty.  I was eyeing up the CaseMaker 5 for example, since the inside can mostly be removed for better air flow(since I won't need hard drive cages). So for under $3,000(all towards the tower)... What should I be considering? Should I be doing the new Skylake for DDR4? Not worth it? Show me some options, some builds. I look forwards to doing this all soon!
https://linustechtips.com/topic/620810-trying-this-forum-for-help-d/
Here it is- http://pcpartpicker.com/list/LdkYr7
I was really confused with storage. So I added everything edit that as per your needs. Also, the extra fans are for the Radiator if you didn't already figure that out.
Hardcore Hardware Whore | Check out my Blog for for Latest Tech News and more | Cricket Fan | Weapons Nut |
I think I nailed it:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core OEM/Tray Processor  ($337.88 @ OutletPC)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($93.99 @ Newegg)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard  ($85.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($52.99 @ Newegg)
Storage: MyDigitalSSD Super Boot Drive 128GB M.2-2242 Solid State Drive  ($44.99 @ Amazon)
Storage: Western Digital 3TB 3.5" 5400RPM Internal Hard Drive  ($98.99 @ Amazon)
Video Card: MSI GeForce GTX 1080 8GB Video Card  ($649.99 @ SuperBiiz)
Case: Corsair Vengeance C70 (Black) ATX Mid Tower Case  ($109.99 @ Amazon)
Power Supply: Antec TruePower Classic 750W 80+ Gold Certified ATX Power Supply  ($59.99 @ Newegg)
Total: $1534.80
Generated by PCPartPicker 2016-07-04 11:35 EDT-0400
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
