2 minutes ago, Dwood180 said:
I'm wanting to know what 1080 is best for overclocking if I'm planning to water cool?
thanks
They all perform pretty darn close to each other, within 1 or 2% so there is no real winner here. Only thing we suggest is to stay away from the ASUS GPU's as they have a horrible QA and a worse RMA/Customer Service issue.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
thanks
EVGA FTW
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Can you get a water block for the FTW though?
EK will soon have them.
Late July it says
https://www.ekwb.com/news/official-list-of-ek-water-blocks-for-gtx-1080-series/
Old Rig
I CAN VOUCH FOR THIS
RIP MY ASUS R9 270
YOU SERVED ME WELL FOR 3 YEARS
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
20 minutes ago, SeanAngelo said:
EVGA FTW
Even though they all perform nearly identical, EVGA does get my vote for superior customer service and all around products.
Community Standards
"Beast Mode"
19 minutes ago, SeanAngelo said:
Thanks for the info. I'll go EVGA then and waiting for the water block to come out doesn't look like a issue since so far everywhere I have seen so far all the 1080's are sold out. :(
Evga classified.
You'll want to go evga since you don't lose your warranty if you change the cooler.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
MSI Lightning
ASUS ROG Matrix
EVGA K|NGP|N
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
13 hours ago, DXMember said:
MSI Lightning
ASUS ROG Matrix
EVGA K|NGP|N
13 hours ago, Pohernori said:
Evga classified.
14 hours ago, SeanAngelo said:
EVGA FTW
Ok just one more question. I noticed on EKWB the water blocks state that they aren't compatible with the new SLI bridges. Is there any blocks that will be compatable?
well its hard to say, unless they completely redesign the sli bridges or redesign the way that waterblocks receive the water.
Old Rig
yeah, you can just cut off the excess acrylic
or use the floppy bridges... it doesn't really matter
