Hey guys, so I made and earlier post for asking what I should buy, for making my own gaming PC. Some people send me some builds and I really liked their builds. Now I'm not sure if it will change my build. Because in the original build there was a Micro ATX motherboard. Will it change a lot? In the case.. the memory etc..? http://ca.pcpartpicker.com/list/LXDNNNhttp://ca.pcpartpicker.com/list/LXDNNN  Heres the build I wanna make.
SO will it change a lot of I go with an ATX board and not a micro?
https://linustechtips.com/topic/619887-will-it-work/
Itll work fine, youll just have more expansion slots.
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999863
Hey,
your missing a power supply. And if you intend to use wifi, your issing a wireless adapter. Also unless you work with sound all day, there is no need for a sound card. Lastly, instead of using the r9 380, get your hands on an amd rx 480. The rx 480 is only $200 and way more powerful in all aspects than the r9 380.Just my suggestions.
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999875
I would go with an Atx board, they are usually more reliable, problem-free, and have more features.
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999883
The form factor does not impact the stability or "problem-freeness" of a MB, it does however dictate what features are available.
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999900
In low end mobos like the one in his part-list, form factor most definitely impacts the stability and "problem-freeness"s. DO your research.
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999920
4 minutes ago, thutzell13579 said:
You also need a CPU cooler. i5 skylake series does not come with CPU coolers.
Only the K series don't
3 minutes ago, Sander Van Dam said:
Oh damn, didn't notice that there was missing a power supply, thanks, guys. And ill make the changes... Thnx Thutzell13579
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($251.55 @ Vuugo)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($64.72 @ Amazon Canada)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory  ($45.98 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.55 @ Vuugo)
Video Card: MSI Radeon R9 380 4GB Video Card  ($244.99 @ NCIX)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case  ($54.99 @ DirectCanada)
Power Supply: Corsair CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.98 @ NCIX)
Total: $788.76
Generated by PCPartPicker 2016-07-02 12:37 EDT-0400
No need for soundcard
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999922
Nice build suggestion, I would just substitute the 39 380 for an rx 480. The rx 480 is more inexpensive, and way more powerful.
Total: $788.76
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999937
5 minutes ago, Sander Van Dam said:
I need an Atx motherboard tho, not a Micro Atx and maybe replace the Hard drive with an SSD
Why?
The RX 480 is $100 more and I know it's much more powerful. Also, I'd wait for the Sapphire one c:
USEFUL LINKS:
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999959
PCPartPicker part list: http://ca.pcpartpicker.com/list/VHgf8K
Price breakdown by merchant: http://ca.pcpartpicker.com/list/VHgf8K/by_merchant/
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($200.95 @ shopRBC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($32.00 @ Amazon Canada)
Motherboard: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard  ($57.49 @ Newegg Canada)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($39.98 @ DirectCanada)
Video Card: XFX Radeon RX 480 8GB XXX OC  Video Card  ($334.99 @ Memory Express)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($52.55 @ Vuugo)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($64.99 @ Amazon Canada)
Total: $842.50
Went a little over budget but this should be a pretty cool build
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999965
I need an Atx Motherboard and not a Micro Atx, because I want to put in an Elgato HD60 pro. Isn't and SSD better than a Hard Drive, when it comes to gaming? Also one thing that is missing is a Cpu cooler. Not a big fan of basic fan cooling? What should I buy?
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999971
Just now, Sander Van Dam said:
*snip*
SSD is just faster than a hard drive.
PCPartPicker part list: http://ca.pcpartpicker.com/list/grjM8K
Price breakdown by merchant: http://ca.pcpartpicker.com/list/grjM8K/by_merchant/
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard  ($79.99 @ NCIX)
Case: BitFenix Shinobi Window (White) ATX Mid Tower Case  ($39.88 @ Canada Computers)
Total: $852.33
This one has a ATX mobo.
https://linustechtips.com/topic/619887-will-it-work/#findComment-7999991
1 minute ago, Sander Van Dam said:
Could I change the Case for:
http://ca.pcpartpicker.com/product/tD38TW/nzxt-case-cas340wbr1
and maybe have an SSD?
Hmm, you can downgrade the CPU and get the case but I dont think the ssd is needed, especially since you can upgrade it in the future
https://linustechtips.com/topic/619887-will-it-work/#findComment-8000012
The HD60 pro will work in any motherboard that has a PCIe x1 slot. That include mATX motherboards.
USEFUL LINKS:
https://linustechtips.com/topic/619887-will-it-work/#findComment-8000037
