I'm looking for a micro ATX case that is below $60 CAD for my custom PC build. It would be amazing if someone could help me find one that can fit inside these dimensions (measurements in inches) >15x>9x>15 (H*W*D). I currently plan to get the Fractal Design core 1100, it MOSTLY fits within my dimension by it being an inch to deep.
https://linustechtips.com/topic/619509-help-finding-a-case/
Core 1000?
https://linustechtips.com/topic/619509-help-finding-a-case/#findComment-7995892
