2 minutes ago, Hahzi said:
I have been looking at a fairly cheap built so far and need to know if a  AMD Athlon X4 880K Is a strict upgrade from a AMD A6 7400k And if The Athlon is a APU also If I buy a APU do I need to
buy a video card? - Console peasent
APUs have an integrated graphics processor,  but they're not powerful. You'd be better off with an i3 and a Gtx 950.
ASU
https://linustechtips.com/topic/619384-need-some-advice/#findComment-7994624
if you buy an apu you do not need to buy a gpu, allthough a gpu IS HIGHLY RECCOMENDED
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/619384-need-some-advice/#findComment-7994625
40 minutes ago, Hahzi said:
Is the Athlon a APU though?
No, the a10 7850k or 7870k are the apu equivalents to the Athlons. I can't recommend apus for gaming though. They bundle weak cpus with anemic gpus
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/619384-need-some-advice/#findComment-7994853
Buy a gpu, you wont regret it
https://linustechtips.com/topic/619384-need-some-advice/#findComment-7995441
If you're just going to do light gaming, an APU will suit you fine. Just make sure you get a high-end A10 or it won't perform well. However, if you can stretch your budget, definitely go for an i3 and GTX 950 - it'll be a lot better. If you can't, though, an APU will manage light games perfectly fine.
N.B. Athlon is not an APU, you need to get an A-series (A10 preferably).
CPU: i7 6700k (4.7 GHz) | GPU: EVGA GTX 1070 FTW (OC) | Motherboard: ASUS Sabertooth Z170 S | Cooling: Corsair H110i GTX | Storage: 250GB Samsung 850 EVO M.2 + 1TB WD Black | RAM: 16GB (2x8) Corsair Vengeance LED (White) 3000MHz | Case: Phanteks Enthoo Evolv ATX | PSU: Corsair RM850i | WiFi Card: TPLink Archer T9E | Case Fans: Noctua iPPC-2000 PWM (3x 120mm in), 2x Noctua NF-A14 PWM 140mm (radiator, painted black), Fractal Venturi HP-14 (1x 140mm out)  | OS: Windows 10 Home 64-bit
https://linustechtips.com/topic/619384-need-some-advice/#findComment-7995461
