2 minutes ago, mathmeister said:
My PC will be on the left side of my desk and I was wondering if there are any cases with the side panel on the right side. I've look at the 600C but I don't want to spend that much, my case was going to be the S340 which is half the price of the 600C.
Bitfenix Prodigy can have the window switched to the other side but the system won't magically invert itself. Inverted cases are basically brand new and you're gonna have to get something the price of a 600C to get a properly inverted system.
https://linustechtips.com/topic/619368-right-side-windowed-case/#findComment-7994479
 inverted has been available for a while but it has limited options and tends to be expensive as it's a niche market.
Be-quiet dark base 900, raven RV01 / RV02, custom mod.. Some cases are easily modable by drilling out a few rivets and flipping.
Not too many options.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/619368-right-side-windowed-case/#findComment-7994542
