Technically yes, speeds aren't just meaningless, but a given user won't notice a difference at all as long as the rest of the PC supports the speed.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
Makes a massive difference if you need it, doesn't make a difference if you don't. Somewhat higher speed grades don't cost much more, so worth a look if your mobo supports it.
37 minutes ago, TheMidnightNarwhal said:
So I know it wasn't that important with DDR3 and the norm was to get CL9 1600mhz and that was fine. What about DDR4 now? Does it matter was latency or speed you get or?
doesnt matter unless youre running apus(when they use ddr4
In what cases or uses does it matter?
Compute activities where the working data set is greater than the CPU cache. In my case, finding large prime numbers, similar in loading to Prime95. There may be others but that is one of interest to me.
