Hey guys. I just got a gtx 1070 g1 gaming from gigabyte, and I noticed the 3rd fan to the right was hitting the plastic shroud when I spun it with my finger. A few times it would stop, and the rest of times it would create clicking noises. Obviously I don't hear this when the pc is idle because of the fan stop thing, but when it is under load, it is audible. It's not loud, but it's not inaudible. What do you guys think? Should I RMA it? Would newegg even allow me to return it? Any suggestions? Please let me know.
https://linustechtips.com/topic/618288-gpu-clicking-noise/
I don't know if they would take it as an RMA but I would find it annoying, if you want to see the return policy it should be present with your electronic receipt, if I'm remembering correctly. If not just go to newegg and look for their return policy in the customer support section, but it may take a while to get another one due to supply if you do decide to RMA or return it to newegg.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/618288-gpu-clicking-noise/#findComment-7981908
I would see if you could RMA it if it is indeed the fan contacting the shroud, that's basically a manufacturing defect. If not, time to bring out the dremel.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/618288-gpu-clicking-noise/#findComment-7981910
On 6/29/2016 at 3:25 PM, Ajaydev Singh said:
Check if there is something touching the fan If not I would RMA
On 6/29/2016 at 3:21 PM, EnemySp0tt3d said:
Check the inside of the fan blades in and around the shroud to make sure there is not anything touching it. I was about to RMA my 970 before I found out that there was a small wire barely touching the blade.
I looked at it closer again, and there is a wirelike thing underneath which the fan was hitting. All it needed was a slight push down and now it is flawless :)
https://linustechtips.com/topic/618288-gpu-clicking-noise/#findComment-7982064
