What should I go for?
I know the Hof is clocked a little higher than the Amp extreme but I was wondering which of these is an all round better card when you take the software (firestorm vs what Galax has), power phases, and cooling into account. Also I think the amp extreme has a higher memory speed than anything else I've seen so how important/impactful is that?
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/
980 ti? 980? 1080? 1070?
what gpu are you looking at?
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7978631
2 minutes ago, Loosh said:
1080, sorry should have been more specific!
the 1080 HOF isn't even out yet, is it?
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7978642
Amp! Extreme:
  • 2560 Cores
  • Base: 1771 MHz
    Boost:1911 MHz
  • 8GB GDDR5X / 10.8 GHz / 256-bit
HOF:
  • CUDA Cores 2560
  • Base Clock (MHz) 1809
  • Boost Clock (MHz) 1961
  • Memory Speed 10Gbps
These are the official clock speeds for both cards,
Can anyone tell me anything about the importance of memory clock speeds on a card like the 1080? Does it actually make a difference or does it just get to a point were its not really that important? Cuz the Zotac memory is 800 MHz faster than the HOF.
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7978668
3 minutes ago, Loosh said:
Amp! Extreme:
  • 2560 Cores
  • Base: 1771 MHz
    Boost:1911 MHz
HOF:
  • CUDA Cores 2560
It probably wouldn't make much of a difference
~ Main Rig ~
- Ryzen 9 3950X 16 Core 32 Threads - EVGA 3090 KINGPIN HYBRID - 32GB DDR4 3600mhz -
- 6TB SSD Array + 2TB MP600 NVME Gen4 Boot -
- Gigabyte X570 AORUS MASTER - Lian li O11 Dynamic XL - NZXT Kraken X73 + 16 Noctua NF-A12x25 Fans -
~ Accessories ~
- Logitech G915 + G903 - LG C9 OLED PG279Q 27'' [1440p 165hz G-Sync] +  PG27AQ27'' [4k 60hz G-Sync] -
2x 1440p Portrait 25'' Dell - DT 990 Pro Headphones -
~ Servers ~
- 100TB NAS + Server's w/ 6700k - 32 + 64GB Ram - NVME Boot - Gigabit Unlimited Fiber -
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7978682
5 minutes ago, Loosh said:
Amp! Extreme:
  • 2560 Cores
  • Base: 1771 MHz
    Boost:1911 MHz
HOF:
  • CUDA Cores 2560
The HOF will still probably perform slightly better, those extra 50 mhz on the core should provide about the same, if not the same performance as the 800 mhz on the memory.  The HOF should have a tiny bit more OC headroom as well, and the memory should go just as high as the zotac, if not higher.
Where are you seeing it's available for pre-order? I can't find any info on that
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7978685
Wait hold on i think i might of messed something up. I was looking at overclockers.co.uk.
They had the KFA2 HOF, with clock speeds set as TBD. But I assumed that KFA2 and Galax are exactly the same but with different names for whatever reason.
But i just checked the KFA2 website for their HOF listing and the clock speeds were a lot less than the GALAX HOF which doesnt really make sense. I'll provide all the links so you can have a look.
https://www.overclockers.co.uk/kfa2-geforce-gtx-1080-hof-8192mb-gddr5x-pci-express-graphics-card-gx-089-kf.html
http://www.kfa2.com/1080HOF.html
http://www.galax.com/en/graphics-card/hof/galax-geforcer-gtx-1080-hof.html
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7978713
The one with 1961 boost is a "limited edition" one, the standard one is 1873
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7978739
1 minute ago, Loosh said:
Oh, my bad... :/
Sorry for wasting everyone's time I guess :P
Either way, if the Amp Extreme is cheaper just get that, both will clock very similar because of how Pascal works.
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7978753
Cant say anything about the 1080. But the 980Ti amp!extreme is a Monster.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/618016-amp-extreme-vs-hof/#findComment-7979955
