Making On/Off LED Switch?
Solved by rhyseyness,
4 minutes ago, AllHokage said:
Yep just like that ![]()
Perfectly safe as long as you make sure the exposed metal on the switch/wires is completely insulated (shrink wrap).
Also make sure your switch is rated for enough current.
Can't remember what the Molex spec is off the top of my head, but shouldn't be more than 5 amps ![]()
