I'm on my previous machine, an 3570k and for some reason the difference in temp from my first core to my last core is 10 degree's C at idle.  This is a second and different AIO and different thermal compound, but just yesterday I had the same issue on the last cooler.  Any thoughts? I haven't put it under load yet but why would one core run that much hotter than another?
Audio go Brrrrrr
https://linustechtips.com/topic/617797-aio-variation-between-core-0-and-3/
1 hour ago, Psittac said:
a quick loading of folding at home and it's the same at load, I watch resource monitor at idle and no one core is getting worked harder than another.  Do I need to delid this cpu and change the tim?
That would most likely fix your issue if you're prepared to void the warranty. My CPU isn't the best either and I get 6C variation sometimes but I just don't think it's worth the risk of delidding.
CPU - Ryzen Threadripper 2950X | Motherboard - X399 GAMING PRO CARBON AC | RAM - G.Skill Trident Z RGB 4x8GB DDR4-3200 14-13-13-21 | GPU - Aorus GTX 1080 Ti Waterforce WB Xtreme Edition | Case - Inwin 909 (Silver) | Storage - Samsung 950 Pro 500GB, Samsung 970 Evo 500GB, Samsung 840 Evo 500GB, HGST DeskStar 6TB, WD Black 2TB | PSU - Corsair AX1600i | Display - DELL ULTRASHARP U3415W |
I wouldn't do it on my new cpu for the very same reason.  I've had this one for a while so I'm not to worried about it.  Also I'm afraid I'll end up hurting myself in the process ><  Honestly I don't remember if it had that drastic of a difference before, I didn't run temps after I clocked it and burned it in so who knows how long it's been like this.  Also my clock seams a little low, could of swore I got it to 4.4 but when I booted into bios it was 4.2
Audio go Brrrrrr
  • 4 weeks later...
ok so I just got my main rig running again with a custom loop and it's doing the same thing.  Core's 0,2,4 are 20c hotter than cores 1,3,5 when running prime95
What's the deal? I used that coolabratory TIM on both.  Did I apply it wrong? Not sure what's going on here
Audio go Brrrrrr
