Okay, I have  AMD A10-7700K Radeon R7, 10 Compute Cores 4C + 6G 3.40GHz CPU, an AMD  HD 7700 GPU, 2X4GB  hyperx fury 2133mhz RAM memory, and im trying to upgrade my GPU but i dont know which graphics card is best for me, i have a budget of 200 dollars, please help me find the best GPU for my build :)
https://linustechtips.com/topic/616967-i-need-some-help-pls/
Wait to Upgrade to the New RX 480. it will be available this june 29. and the cost is around 200$USD, for now i saw the leaks that can run games on high settings at 60+FPS.
but check if this does not bottleneck your CPU or i think this case is a APU right?
https://linustechtips.com/topic/616967-i-need-some-help-pls/#findComment-7966002
The RX 480 comes out and a few days and it should be a pretty good GPU, that'll likely be your best bet unless you're interested in seeing what NVIDIA has to offer, my only concern is that your APU may bottleneck it slightly.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/616967-i-need-some-help-pls/#findComment-7966016
Literally like the others have said, for $200, wait for the RX 480. 980 performances for $200. It's only a couple more days.
https://linustechtips.com/topic/616967-i-need-some-help-pls/#findComment-7966018
