so i have oc'd my 1080 to 2100 mhz boost and 5508 mem but it sits at 80-83c, my question is since i only gain 9-10 fps avg for about 8-10C higher temps over stock would it actually be worth running it at 80-83c OC'D vs 70-73c stock for long term gaming use?  i have the EVGA 1080 FE
https://linustechtips.com/topic/616425-1080-overclocking-question/
Check your privilege
/salt
Welcome to the forums! :)
I'd recommend changing the fan curve to be more aggressive in your OC software.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
/salt
thats with fans at 100%. i have it set to go to 100% at 60c and it will still climb to 80-83c depending on how hot it is here and i use the same fan curve on stock too
Wow. Ok so I would tune down the overclock because of the noise and I would want to preserve my GPU to last (especially if it's a 1080, you are getting great performance already)
The cooler sucks since it is a blower. It's not going to get better.
Better off getting a waterblock for the card to keep it cool. Cut the load temp in half.
thats the thing i have to have it at 100% to even keep it at 70-73c at stock any lower and it climbs to around 80c even stock clocks
Well if you are happy with performance at stock, have it at stock.
Depends on that 10 fps difference ... if you usually have 50 fps, and OCed gives you 60, I would OC it for sake of vsync.
But if you get 100fps with OC, just leave it at stock. 90 fps is still plenty :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
