3 minutes ago, SteelHaddock said:
hi my fans the Corsair CO-9050008-WW Air Series SP120 Performance Edition 120mm High Pressure Fans keep making a loud noise. Is this normal or is there any way to stop them?
These fans are made for coolers or radiators, for your case you should use the AF series. Also, check your speeds with SpeedFan or your motherboard software
Sorry for Bad English, Baguette here
STENDHAL: CPU: i5 6600K | MOBO: ASUS MAXIMUS VIII Ranger | GPU: MSI GTX 1070 GAMING X | RAM: 2x8GB Corsair Vengeance LPX 2400MHz | Case: CM HAF XB | Storage: Kingston UV400 240GB SSD + 750GB WD Blue | CPU Cooler: Hyper 212X | PSU: Corsair RM750X
https://linustechtips.com/topic/615816-fans/#findComment-7954304
They're not quiet fans.
Have you tried lowering the fan speed?
https://linustechtips.com/topic/615816-fans/#findComment-7955335
