Can you look at the circuit board containing the USB and lights from your case? It is usually on the behind the front panel of the case. Examine for damage such as cracked or lose solder joints, burns or detached wires. If that all looks fine, examine the front motherboard header and look for missing pins. Also try downloading the latest USB drivers.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
It all looks fine
Where do I get the USB drivers?
2 minutes ago, No said:
It all looks fine
Look on your motherboards website and go to the support/download section.
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
Thanks for the suggestions, they led me into my BIOS where I enabled Windows 8 Fast Boot which had an option to enable USB Support.
It's fixed :)
It's fixed :)
Glad to hear! Happy to help at anytime! :)
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
