So, recently, I have been playing a lot of Overwatch with no issues whatsoever. Running smooth 90-100 fps on my 980 Ti. However, last week, I started having a framerate issue. I cracked open my PC and re-plugged in the power cords going to my GPU and that did the trick. But now, today, I am having the same issue again. I once again opened up my chasse and re-plugged in my GPU cables, as well as ALL the cables going to my power supply, but that hasn't done the trick. My GPU gets a little warm when playing Overwatch, but not overheating (No pun intended). In the MAIN SCREEN of Overwatch I was having this issue. I also lowered down the graphics settings, and restarted my computer multiple times. This has effected all of my games, some more than others. I honestly don't know what to do at this point. Any ideas?
If needed, here are my specs-
i7-5930k
Gigabyte GeForce GTX 980 Ti WINDFORCE
16 GB Kingston HyperX Fury Black
ASRock X99 Extreme4
Corsair H100i GTX
EVGA SuperNova
2TB SeaGate Barracuda
120GB SanDisk SSD+
Fractal Design Define R4
Please help. If there is anything I can do other than buying a new graphics card (Don't have the money right now to buy one), I will do it.
https://linustechtips.com/topic/614170-wierd-computer-issue-going-on-lately/
Reseat the RAM, check CPU temps, reseat the GPU...
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
i7-5930k
ASRock X99 Extreme4
Corsair H100i GTX
EVGA SuperNova
120GB SanDisk SSD+
What kind of temps are you seeing right now?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
1 minute ago, Joey No Salad said:
My CPU gets into the mid 40's, and my GPU is around 79-80ish degrees Celsius.
What PSU do you have?
1 minute ago, alphaproject said:
Are only games affected? Like nothing else is weird?  If that is the case, I suspect the GPU may be dying a slow death but that's just a guess. Might need to send that baby in for RMA.
D: I hope that's not the issue.
2 minutes ago, Joey No Salad said:
Forgot to type the rest-
EVGA SuperNova 750
I'm going to suggest that you UNDERCLOCK your video card.  By about 10%.  Report back with your findings.
I decreased by 100 MHz, and I'm still getting about 20 fps. Should I go lower?
Make sure you decrease the clock speed AS WELL as the power settings.
