My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/614147-thermaltake-smart-650w/
2 hours ago, astranger200 said:
Generally best to avoid Thermaltake. Check out the PSU whitelist in my signature for lots of good options. I know Australian costs for PC parts are ludicrous but you need to spend a good amount of money on a PSU if you're gonna be powering a 290X.
https://linustechtips.com/topic/614147-thermaltake-smart-650w/#findComment-7935512
Thermaltake is a company that likes to mixed two or more different platforms within a series, so it is often confusing to keep track of them. Unlike the 750w counterpart, the Thermaltake Smart 650 is based on the CWT DSA-II -  identical to the Corsair CXv3.
In the same price point, you could get the Antec Neo Eco II 650w. It's the new, updated APAC-version (Asia-Pacific) version of the VPF model as shown in this review but with 100% Japanese caps and sleeved cables (rather than exposed multi-color). It's a better quality and better performing unit than the what you are getting.
http://www.msy.com.au/sa/adelaide/pc-components/16500--antec-neo-eco-ii-650w-80plus-bronze-650watt-power-supply-unit.html
https://linustechtips.com/topic/614147-thermaltake-smart-650w/#findComment-7935715
ended up spending a bit more and got this
http://www.msy.com.au/sa/adelaide/650w-750w/15134-coolermaster-gm-series-rs650-amaab1-650watt-80-bronze-semi-modular-power-supply-unit.html
its not the best, but its plenty of wattage, good build quality and has good reveiws including from johnyguru...
also semi modular...
https://linustechtips.com/topic/614147-thermaltake-smart-650w/#findComment-7936392
Not a bad choice. Have fun with your system!
https://linustechtips.com/topic/614147-thermaltake-smart-650w/#findComment-7937721
