Have a question for the community:
Can you use higher frequency RAM in a motherboard above what it's specs include?
Im putting together a used parts build and while shopping for RAM haven't had much luck with DDR3-1333 (the highest frequency the motherboard lists compatible) and I was hoping I could get away with using DDR3-1600.
Oh, I'm using a Xeon X3450 processor on an Asus P7P55D-E motherboard.
Thanks in advance!
https://linustechtips.com/topic/614126-help-with-ram/
