CPU fans
MYX
hello all, I am buying a new cpu cooler for my pc, right now I have a AMD Athlon 860k in a ASUS 68HM motherboard, I was wondering if I could put this fan in here.https://www.amazon.ca/Xigmatek-Profile-Cooling-Janus-LD1266/dp/B00LO3KGZQ/ref=pd_sim_sbs_147_3?ie=UTF8&dpID=41XwLxbf-nL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&psc=1&refRID=QDSYMJEY9SH5S7EHP784
Thanks!
btw I'm switching out the fan because the AMD stock cooler sounds like I have a bee hive in my pc ;)
Use pcpartpicker to check compatibility with it by selecting your motherboard, cpu, and the cooler.
Also you could just get the hyper 212 evo because it's probably better and cheaper than the one you listed.
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
That cooler would fit just fine.
Is there any reason you're getting that as opposed to a better performing traditional tower heatsink? http://www.directcanada.com/products/?sku=34971103632
