I just watched the video
and Linus talks about how you should only buy a power supply that has a continuous wattage rating instead of a peak rating. So I decided to look at some different PSU's and I can't tell the difference between a PSU's that have a peak or continuous rating, they all seem to just give a wattage rating. For example, this is my PSU - Thermaltake 700W LT-700AL2NL - I can't tell if it's 700W peak or continuous 700W.
Any help would be greatly appreciated, thanks.
https://linustechtips.com/topic/613426-peak-vs-continuous-wattage-help/
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
peak wattage is where the power supply can deliver a wattage rating for a short period of time (maybe a few seconds or a few mins) and continuous rating is where it can deliver the specified wattage forever with no issues :D...or in theory it shouldn't blow up if it's not made using shitty components.
For your question about your PSU, I don't know :/ and too lazy right now after I completely rebuilt my PC (which seem to have solved the black screening and power surge issues :)).
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
7 minutes ago, DXMember said:
The OP mentioned that the PSU is no longer rated at 500W CONTINUOUS but instead rated at 450W CONTINUOUS, how did he know it was continuous wattage instead of peak wattage?
I understand the difference Linus explained that well, but what I don't understand is how to tell the difference between a PSU rated at X watts continuous or X watts peak.
I'm unsure as some companies are sneaky and doesn't say whether it's continuous or peak...this usually requires some research :P
Research as in asking in forums looking at reviews etc.?
Yah, asking forums is good and I would do some for you but I'm too lazy right now :/
I'm not 100% sure on this, but I think that 80+ rated power supplies must give the continuous power output.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
1 minute ago, MDH said:
Oh :( haha. I've been looking everywhere and no luck so far.
9 minutes ago, quan289 said:
A proper, continuous rated 700w PSU would not have the 12V rail rated under 50A / 600w.
Anyways, here (scroll down to the power distribution chart ) : http://www.thermaltake.com/products-model.aspx?id=C_00001776
It says it's peak 700W but thing is, there's technically 52Amps on the 12V rail so...I guess it could be 700W continuous :P (as that includes the 3.3V and 5V outputs).
So this PSU is a proper continuous rated 700W PSU?
tested it or looked at manufacturers product page
No. The 30A and 22A rating are not additive; otherwise, that would be like saying the Antec High Current Pro 850 Platinum can output 160A off of the 12V rail (1920W) because it has four 40A.
That 30A and 22A rating are like virtual limitation set by a set of protection (Over Current Protection). It's a safety feature to ensure that a certain group wires doesn't draw more than it should in an event of a short.  That rating doesn't tell you the actual 12V rating.
No, it is not.
whoops, forgot about how they don't add up...not dealt with a multi-rail PSU for too long :/
No, it is not.
Could it safely run a system at 620-650 watts? If not, could you give an estimate at what max wattage would be safe?
