So i watching videos on how to run ATI and Nvidia GPUs in the same PC. Before building my PC i was determined to buy the GTX 970. But then the 1070 arrived and i thought it'll be just better to wait and use a used GPU as it was the only component remaining in my build. So i opted for a used ATI 7870 which i got for $108.
  System :
 CPU - Intel® Core™ i7-6700 Processor
  • MotherboardGigabyte GA-H170-Gaming 3
  • RAM16Gb G.SKILL Ripjaws V DDR4 2400 C15 (2x8GB)
  • GPUSapphire AMD/ATI HD 7870OC Edition 2 GB GDDR5
  • CaseCooler Master: CM 690 II (ver.2)
  • StorageSamsung 850 Pro 128 GB SSD, WESTERN DIGITAL 1TB Caviar Green HDD
  • PSUCooler Master: GX 650W
Since i use my PC for work and medium-light gaming, i wanted to know whether using ATI and Nvidia both in my PC will benefit anything. Just to be clear i mainly concerned about using software applications like AutoCAD, 3DS Max, Adobe Photoshop, Google SketchUp+Vray. I don't wanna bother myself about the advantages of Physx in Arkham City. So keeping that in mind, is there any benefit of using Nvidia and ATI together, ATI as i primary card and Nvidia as a physx card.
Are there any other benefits i can take from using them together for work purposes? Also i watched a few videos about Hybrid PhysX but they are basically concentrated towards gaming.
Note: If this set up still works i will opt for a used Nvidia card, again.
links:
Keep it simple.
https://linustechtips.com/topic/613395-hybrid-physx-amd-nvidia-for-work/
Im not following.
Are you wanting a physx card for things OTHER then gaming?
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
1 minute ago, titaniumshield said:
Yes.
Ok I have no answer then ...frankly i dunno what the hell else would support it...
I only know of things using cuda rendering.
System Specs
So if i use the Nvidia card, will i be able to make use of CUDA?
Keep it simple.
Honestly I dont know. I'm not going to say you can or cannot do this or that because you are dealing with a very unorthodox situation that is almost NEVER the best way to go and little research is done on it...
I have heard nvidia drivers get REALLY pissy when you try to run an AMD card in tandem though. So something to keep note of but even that is kinda a weird situation right now with DX12.
System Specs
When an AMD card is present, Advanced PhysX doesn't work anymore, which occurs on the GPU. PhysX gets forced onto the CPU.
Not possible, you need nVIDIA GPU's in the same system, for example, GTX 680 dedicated and GTX 460 physX.
let us all remember now and today, computers do not like abuse, they will fight back!
Old Skool KILLBOX. XEON E5640 4.0ghz / ASUS P6X58D-E ~ Noctua NH-L12 ~ eVGA GTX 670 SC 2GB 1312/7000 ~ 4TB 7200 RPM RAID0 ~ CoolerMaster Haf 922 ~ DELL P214H 23" 1080 IPS 2ms ~ HP w2007v 1680x1050. Now Playing: Splinter Cell OG XBOX / CSGO PC
Original XBOX - Xecuter 2 4981.67 Bios. Playstation 2 Slim SCPH-70002. Sega Dreamcast. N64
2 hours ago, titaniumshield said:
So are you all saying that this 'Hybrid PhysX ' trickery is not possible now anymore like it used to be?
Correct. NVIDIA updated their software so any detection of an AMD video card will render Advanced PhysX unusable.
To add to this, I think it also disables all Nvidia exclusive features making this setup completely useless.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
yes
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
What about the other way around if I have a primary nvidia gpu and a amd gpu for doing other things?
5 hours ago, titaniumshield said:
If there any advantage of using both of them together?
not really, usually people just pick one - either they want OpenCL - then they go AMD, or they want CUDA - then they go nVidia,
but both Google and AMD are working on OpenCC and CUDA translator so that might change in the future as nVidia does gut a lot of compute power out of their gaming cards
