Afternoon peoples,
I'm about to built a new PC, and wanted to know if this Flex PSU will work for me.
http://www.newegg.com/Product/Product.aspx?Item=9SIA6PW3S08854
PC setup require 300-350 watt total.
Mini-itx MB, GTX 960-970, 2x8gb ram, i5-6600k, May/May not OC.
Why that psu? form factor is most important here.
I know it's design for server, but it has the amount of juice I need, I just don't know how their power is distributed; like can it run, will it be stable, etc.
I'm a novice, do excuse my mistake.
https://linustechtips.com/topic/613049-flex-psu-for-desktop-pc/
12 minutes ago, 4King said:
Afternoon peoples,
Flex ATX PSUs work in only very specific chassis, usually server units. What is the case you're putting your components in?
https://linustechtips.com/topic/613049-flex-psu-for-desktop-pc/#findComment-7922611
5 minutes ago, 4King said:
-SNIP-
Welcome to the Forums!
A flex atx of that capacity would be enough for your system but I would probably go for something a bit more reliable as I've never heard much form solid gear.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817104195
https://linustechtips.com/topic/613049-flex-psu-for-desktop-pc/#findComment-7922843
I'd think it should be fine, but it will probably be rather loud when stressed (or maybe even, always).
I'd also suggest you get a GTX-1070 or RX 480 rather than a GTX-970 for the lower power requirements.
Btw, I haven't heard of Solid Gear or FSP, so I can't say if that matters.
Have you checked to see if an SFX power supply will fit?
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/613049-flex-psu-for-desktop-pc/#findComment-7922925
