NOOB WARNING - need help with airflow
Solved by soggyfatman,
I think the h80i will do just fine in the back as exhaust. But in gerneral, I think you always want a positive air flow, like more air in than air out. Way to do that is just do some simple math! Add up all the fans cm/hr or whatever unit and subtract the exiting air amount. I think 2 140mms in the front with your exhaust and 2 up top will do just fine since you will have 2 on the side to give it more air. If you are not worried about noise, load that baby up. Most h80i's ive seen have been on that rear single fan on the back so I asssume it is good to go.
