Linus need you help
Go to solution Solved by Michael.pence68,
Ok first off it was built by com capital they ran it for so call 2 days!with no problems,when we brought it home we didn't want to install the new 590 which evga installed the gpu water cooled blocks pre built just incase.we used a 660 ti when we got it home it sprung a pool of water mind you the 660 ti was installed by com Capitol we just plugged it in and pop water leaked from the CPU to pump. I guess they never checked for bubbles or leaks. They slapped it together now they say it's our fault or defected swift tech and other components in the water cooling product now we have to call all swift tech and other companies to see if they will stand behind there product.com Capitol said there not in fault cause it's a customs machine.how's that better English sorry I'm not thinking right.my brother has no concept of money is what I meant.he believes com Capitol that there not in fault.so he will have someone else build it then to here com Capitol is not in fault.just how he is easy going with lots of money my brother that is.and sry about the first write up 2 babies I'm watching my head hurts. But do 590 gtx still cost the price as titans I no evga installed the water blocks but they cost 2,000 a piece before now there 1,000 us a piece there 2 year ago gpu's. And is it possible to save the mobo and CPU ,and memory even if it was water logged. Plus I believe the builder is in fault correct we only had it home for 30 mins so I don't think it ran at com cap for 2 days straight with no problems how's that my grammar is a little better right? Just nervous thanks
Ok my brother bought can't believe it but 2 gtx 590 I think at comp Capitol hate that store but each card was reduced from almost 2,000 us to like 980 us way so much but don't no why he didn't buy titans for that price and I bet even with the cooler blocks installed I could be wrong. But so he has to of them and need to get full water blocks anyhow thank god only the motherboard processor was installed by them with swift tech water cooling and it popped it seems gallons came out the first 30 mins he started it up with they said worked great no leaks for 2 days.they said we must of screwed it up by installing the cards and taking hoses off not true. We tested it before customizing it 30 mins I swear a bomb went off the board case and psu is soaked are we screwed? It's a Maximus Iv extreme 1150 with 4770k and veg enhance 16 gig ram he does camera and video editing. No grafixs were injured when this happened guess Monday we will have you build a new one I guess he owns a business and said we will write it off I'd like to salvage it if I could thanks oh see his money is no object that's why he don't care to spend pain time with comp Capitol
Mike
https://linustechtips.com/topic/61206-linus-need-you-help/
1st please check and edit the post so it can make sense you have used the worst grammaahhhh eveah u spelt no instead of know and
took me 20 seconds to figure out what u were saying just for that one sentences if there are any sentences in there =_=
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-833590
My head hurts, I still don't understand the first sentence.  :(
Case = Bitfenix Prodigy, Motherboard = P8Z77 - I Deluxe, CPU = 3570k @ 4.2GHz, RAM = 2x 8GB G-Skill Ripjaws, GPU = Sapphire 7950 Boost Edition, Storage = 256GB Samsung 840 Pro.
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-833607
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-833612
1. You don't need Linus' help. He is a very busy man.
2. I apologize, but what the hell are you saying?
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-833635
I'll try to decode this.
My brohter bought 2 GTX 590s for 2000$ from "Comp Capitol" (which he hates, and he can't believe it) even though the price is only 980$. He could've bought GTX Titan(s) for that price.
and I bet even with the cooler blocks installed I could be wrong. (???)
So he has two of them and he needs to get it watercooled, and THANK GOD he only installed the watercooler (SwiftTech Water Cooler) to the CPU.
And it popped (?) and gallons of water came out for the first 30 mins (WTF). He boot it up and it seemed to work great for 2 days w/o leaks.        wtf
They (maybe friends or technicians) said we screwed it up by installing the water cooler to the cards.
After that. We tested it for 30 mins and a LOUD BANG went off on the motherboard and the PSU is SOAKING WET. Are we screwed? (Yes you are)
It is a Maximus IV Extreme with a 4770K and Vengance Enhance 16G Ram. My brother does mainly video editing.                        god help these people
The Graphics cards are fine. We need suggestions on a new build. He owns a business and we will take note of your suggestions. We would like to reuse (salvage) the graphics cards if we can.
MY BROTHER DOES'NT CARE TO SPEND MORE MONEY ON COMP CAPITOL WHICH IS A PAIN IN THE ASS.
Mike
wow that was hell.
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-833760
dat' signature
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-833780
Please get a pre build system from ncix
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-833793
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-833980
Epic Fail Number 2!
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834011
Today is butcher the english language day apparently, you are the second thread I've looked at in the last half hour that couldn't spell, use punctuation, or even had a sense of proper grammar usage.
01110100 01101000 01100101 00100000 01110001 01110101 01101001 01100101 01110100 01100101 01110010 00100000 01111001 01101111 01110101 00100000 01100010 01100101 01100011 01101111 01101101 01100101 00101100 00100000 01110100 01101000 01100101 00100000 01101101 01101111 01110010 01100101 00100000 01111001 01101111 01110101 00100000 01100001 01110010 01100101 00100000 01100001 01100010 01101100 01100101 00100000 01110100 01101111 00100000 01101000 01100101 01100001 01110010
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834030
I do not intend to sound like an asshole but, can I ask what your language is? Cause I'm pretty sure english is not your main language. If you're lucky someone here might translate it for us.
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834042
Is this them?
http://www.capcomputer.com/about/default.html
Hahaha Piece of $hit PC Products anyone?
Green Machine
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834043
I don't... what.
1383057_10151886270456815_2008508640_n.j
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834047
Is Chicago Illinois not in the USA?
Green Machine
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834049
If your PC got flooded with water while it was running dont expect to any component to be working. If you tested the water loop without power to the other components then just take all things apart and let them dry (week or even more to be safe). Swiftech or any other company will not take responsibility for someone's mistake while putting the computer or watercooling loop. If you got the rig build by someone else take it to them and tell them what happened.
To add - any component that got even slight drop of water on it while it was running is on 99% dead.
How the [insert curse here] can 1155 mobo work with Haswell?
<p>Eryi's Action Rule#2 - "Dont jump on the green mushroom"
Ministry of StopIt!
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834085
I was just thinking to myself "Who else from Chicago can make our country look like an idiot other than the president?"
Well here ya go.
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834101
Well here ya go.
Yep your country is even more stupid lol
Green Machine
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834139
I was going to say this :( why do you take my lines :(
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834209
Mike
wow that was hell.
This OMG hilarious. LAughing can't stop, can't I?
I think the one sentence states that for the price, he could have bought the water block version of the Titan cards.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
https://linustechtips.com/topic/61206-linus-need-you-help/#findComment-834247
