mATX or ATX
depending on what platform you buy.
x16/x16 of course, but that's only possible with x99 atm, and a 500+ dollar CPU.
but as i said, x8/x8, so both cards have the same bandwidth. x16/x4 (H170, B150, etc) should give you some more disadvantages.
Anyway, with which cards do you plan to crossfire? The high end AMDs aren't out yet, and Multi-GPU with low end / mid class GPUs isn't really smart, since multi GPU comes with many many disadvantages. Such as more heat, more power consumption, driver problems, the need of CF profiles, and not a 100% scaling. Depending on game/drivers, you might have only 100% - 170% more performance.
This one for the ATX Build (which I am leaning toward). https://uk.pcpartpicker.com/product/s9Gj4D/msi-motherboard-b150gamingm3
according to the MSI website it has two PCI-Ex16 Gen 3 slots.
Yes, the upper Card will run at x16 speed, and the 2nd one will run at x4 speed.
Suboptimal.
I highly suggest, you switch over to a Z170 board + Overclockable CPU, or you stick to 1 GPU, which is the best choice in general.
