Hello linustechtips forum, I'm looking for help picking the best CPU that can handle the most workload for under $500. My current CPU is an Intel i7-5820k and it's almost always at 95-98% CPU usage. Is there a better CPU I could buy that's under $500.  Thanks in advance.
https://linustechtips.com/topic/611460-help-picking-cpu-to-do-multiple-things/
A very.... how do I say it, "well defined" question. "most workload" means nothing, really. If you could be a bit more specific as to what you do with your PC, it'd make things easier for us.
At any rate, there's no upgrade for you under 500$. You'd need at least 1k if you want an upgrade (unless you can find a used 5960x for cheaper than that).
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
what are you doing to use 98% of a 5820K!!!!????
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
I don't know what you're doing but I get the feeling that it will max any CPU you buy.  I'm not sure anything on the market now will make a noticeable improvement over what you have now.
Thank you for your response. Sorry I'm still new to the whole building pc scene and I'm not quite sure what terminology to use. I use my pc mostly for an application called "osbuddy" which is a client for a game called "old school runescape." I can open and play on about 14-15 of them while watching stream on twitch.tv. I'm looking to be able to open and play on more of the clients with a better CPU if possible. Thanks once again
This is absolutly correct, but even being able to play on 1 or 2 more clients would go a long way in the long run.
I assume you've tried overclocking the chip you have then?
I have not. This there a guide you can recommend me that can show me how to be able to do this?
unfortunately CPU overclocking isn't as simple as using a slider. Thats why I havent overclocked my 4690k
I don't know any particular one specifically but if you just look around online I'm sure there are several good ones.  Even if it's not for that processor, the procedure is the same.  Or, you could start another thread about overclocking a 5820k.
probably that
Do you guys think that buying an Intel i7 6800k would make any difference?
nope
Overclocking or chips $500 or under really aren't going to help you.  Perhaps build a second machine to have on your desk to shuffle some of that workload off of?  I guess you could go to some crazy dual processor E5 setup, but you'll have to drop a significant multiple of $500 for that.
Nope. Not at all. As I said, you need at least 1000$ if you want an actual upgrade.
