Upload speed issue
Go to solution Solved by Thony,
17 minutes ago, Incognitous said:
I've done multiple clean installs and the same issue is always present.
I'm always using a cable, and I've tested using wifi (Wifi to phone, tethered to PC) and then I get the full 10Mbps.
I've tested multiple different drivers and have uninstalled certain software that I've used for proxy's and such.
Not sure how much googling u did but have a look at this if u havent already
http://www.tomshardware.co.uk/forum/45152-42-slow-upload-speed-only
Greetings!
Somehow, for some reason, my upload speed is limited to 1Mbps (Or even less, currently rocking a rock hard 0.3Mbps) even though I'm paying for 10Mbps up. I get 10Mbps up on my phone, laptop, tv and on any other computer I hook up, it's just my main desktop computer that is limited to 1Mbps for some reason. If I tether the computer via the phone, I get 10Mbps up.
Hardware: Gigabyte GA-Z97X-Gaming 3, Killer E2201 LAN Chip.
Software: At the moment, I'm using the "Killer E2200 Gigabit Ethernet Controller (Driver Version 9.0.0.39) " that the gigabyte page about my motherboard suggests I use. It comes with this 'Killer Network Manager' software, which is basically cancer.
I've had this issue for almost two years now, I've tried fixing it myself but to no avail. I've changed drivers countless times, googled everything I can think of and I'm now out of ideas.
If anyone wants any more information to help me troubleshoot what's causing this, I'll gladly supply anything required.
https://linustechtips.com/topic/610668-upload-speed-issue/
are you running multiple devices at the same time because it might be 10 down 10 up for everything on your network
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897147
its sound like your getting 1 MB (megaBYTE) up, which is about what you should get if you pay for 10 Mb (megaBITS). 1 megabyte = 8 megabits
EDIT: nvm, i cant read. your getting 10 mb on every other device
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897179
As I said in the OP, I've had this issue for almost two years now.
And, as I also said, I'm getting the full 10Mbps on everything but my desktop.
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897190
Scan it for malware and viruses.
Check every single Service and options in network settings, antivírus settings. I know on win 7 there was an option to dedicate a certainity percentage of download speed for windows uploads etc. Maybe something similar is happening on your main PC.
Have u tried cable and wifi on that PC ? Do you ha e drivers installed for wifi/cable ?
Clean install windows as last result.
Nothing else come to my mind.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897221
Check every single Service and options in network settings.
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897246
Open the network and sharing centre and see what it says for your connection, does it say "private network" ?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897276
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897341
1 hour ago, Incognitous said:
No, Home network.
I have found that unless my adaptor was set to private network that the internet connection was restricted, but if you have no problems with download speed then I'm guessing that isn't the case as your download looks fine..I don't know what to suggest then really. It's an odd problem as you'd normally have probs with both DL and UL
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897347
I've actually never seen that, mind if I ask exactly what you googled to find it?
It solved my problem and I'm obviously terrible at googling.
Though, I've mainly been focusing on the drivers being an issue since I'm forced to use the drivers and I get the full 10Mbps if I bypass the ethernet all together.
Edit: I'd also like to thank you dearly :)
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897376
LOL great !
"upload speed limited on one pc only"
Your welcome.
https://linustechtips.com/topic/610668-upload-speed-issue/#findComment-7897969
