Sound Card Problem On My Computer
I have a problem with my sound blaster 16 PCI card in MS-DOS 6.22 and Free DOS. I've tried many different drivers and some drivers report that there's no sound card detected.
In DOOM under MS-DOS, there is music but no sound effect unless it's set to PC speaker.
In Free DOS there is no sound unless sound effects are set to PC speaker.
The sound card works fine in Windows 2000 on the same computer.
Can anyone offer help or direction to provide a solution to get full sound om this computer?
My hardware is;
Sound Baster 16 PCI, model number CT 4750.
ASRock G41-GS R2.0 mother board.
4gb of RAM.
A Intel Core Two Dual E8500 CPU.
My autoexec.bat look like this;
@ECHO OFF
SET CTCM=C:\CTCM
C:\CTCM\CTCU /S /W=C:\WINDOWS
PROMPT $p$g
PATH C:\WINDOWS;C:\DOS
SET TEMP=C:\DOS
lh c:\dos\mscdex.exe /d:CDDRIVE /d:DVDDRIVE /m:15 /e /s /v
lh c:\dos\doskey /insert
LH C:\dos\mouse.com
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
SET BLASTER=A220 I5 D1 H5 P330 T6
C:\DOSDRV\SBINIT.COM
My config.sys looks like this;
DEVICE=C:\DOS\HIMEM.SYS
DOS=HIGH,umb
FILES=30
STACKS=9,256
DEVICEhigh=C:\DOS\emm386.exe NOEMS
DEVICE=C:\CTCM\CTCM.EXE
lastdrive=H
devicehigh=C:\dos\gcdrom.sys /d:CDDRIVE /C0
devicehigh=C:\dos\gcdrom.sys /d:DVDDRIVE /C1
https://linustechtips.com/topic/609762-sound-card-problem-on-my-computer/
