Is this safe to use with two graphics cards? Will it burn out the cable? The original cables that came with the power supply also has this dual pcie cable and I have a RM1000i. I was just wondering if both connectors were maxed out would it burn anything out is it safe to max out both connectors at once?
https://linustechtips.com/topic/608829-dual-pcie-cable/
3 hours ago, DEcobra11 said:
Did you buy it as an extension from a reputable manufacturer or did it come with the PSU? if so which one?
Also as it has fully sleeved cables there's a high chance that wire gauge is correct, as that's speding more money when producing it... but that one is strange, looks thin
It's a cablemod custom sleeved cable
https://linustechtips.com/topic/608829-dual-pcie-cable/#findComment-7864374
Which cards are you referring to?
https://linustechtips.com/topic/608829-dual-pcie-cable/#findComment-7878718
They will be totally fine. The cables aren't that thin.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/608829-dual-pcie-cable/#findComment-7878896
