4 minutes ago, Yoo Song Won said:
Mirror's Edge Catalyst, Rise of the Tomb Raider, GTA 5 and so on... AAA basically.
GTA V will be the worst of them, I'd bet. But that doesn't mean you'll be puttering along, no sir.
You should see a solid 60 most of the time.
In any case, the 1070 is a fine choice. If your CPU IS a problem, you can upgrade that in the future.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878358
Probs not but gta will be the worst of all since it is very CPU intensive and i learned that the hard way put you will be putting 50-60 fps stable just remember to turn down grass quality since thats a pain in the ass for fps
My memories of a corpse,mind full of sick thoughts.
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878373
Arma is entirely CPU.
If anything Arma III makes GTA look like a piece of cake
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878384
1440p u gonna okay, 4K u can forget it.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878390
i never played Arma like a barely ever saw the game since i mainly play CS:GO but i heard its very cpu intensive because of the Draw Distance also in Dying Light which sucks for budget builds since they spend more money on a GPU
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878394
Gta V is very CPU intensive, but given that it's a quad core i5, it will probably be fine.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878395
This is not true.  He would be better off at 4k than at 1440p, because 4k shifts the bottleneck to the GPU.  The lower the resolution, the faster the gpu can render images, and the faster the cpu has to provide it information.  At 4k, the framerates are much lower, so the cpu doesn't have to keep up nearly as much as, say, 1080p. This is why an FX 8350 doesn't bottleneck titan X SLI in 4k.
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878474
Shifting the bottleneck to the GPU doesn't remove the CPU bottleneck, especially if we consider a game like Team Fortress 2. This means that the GPU is getting stressed harder, but the CPU is still being stressed the same.
Granted, OP isn't playing TF2, but this is the best example I can give because it's easy as hell to use a Source engine game for an example of how a CPU bottleneck works.
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878484
It doesn't remove the cpu's bottleneck, true, but it does render it meaningless in practical (gaming) terms. If the gpus can only push 60fps then it doesn't really matter to the gamer if the cpu can push 61fps or 600fps, the experience will still be 60fps. It will always have only so much potential, but the importance of the bottleneck depends on whether it's demanding more than that potential or not.
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878494
1 minute ago, ace_cheaply said:
It doesn't remove the cpu's bottleneck, true, but it does render it meaningless in practical (gaming) terms. If the gpus can only push 60fps then it doesn't really matter to the gamer if the cpu can push 61 fps or 600fps, the experience will still be 60fps. It will always have only so much potential, but the importance of the bottleneck depends on whether it's demanding more than that potential or not.
Yes, but if you're being bottlenecked by the CPU, the experience only gets worse when the GPU is also being heavily choked.
This is very apparent in a game that streams most of its content.
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878498
Granted, but as this is hypothetically taking place at 4k, that situation only occurs in less demanding titles. Also bear in mind that I've never owned an 8350, titan x's or a 4k monitor, nor do I stream content, so my opinion is solely based on second hand knowledge.  However, I still believe the 4570 would bottleneck less at 4k than at 1440p, and any issues you run into with the gpu being choked on 4k should only be exacerbated by decreasing the resolution, no?
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7878519
Please provide benchmark evidence. Considering FX is close to i5 i find this very stretched and impossible to believe without seeing it happen.
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7879851
At 4K you are pretty much fully GPU bound on most games.
So for example if you take a GTX1080 and you play at low res like 1080p.
The card can push so manny frames that the cpu has a hard time to keep up with it.
Of course it also depends a bit from game to game, some games tax harder on the cpu then others.
But at 4K the story is allot diffrent.
At 4K a GTX1080 isnt that powerfull anymore, it simply cannot produce as manny frames.
So most cpu´s wont realy have much issues keeping up with it.
Since the load on the cpu doesnt realy change much as you go up in resolution.
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7880201
Not really it is just using one CPU core, in fact many other games are much more demanding but still run better... ;) (best CPU for Arma is a OCable Pentium G or i5)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7880402
I'd put an Skylake i3-6100 against the OCable Pentium G, we all know whos gonna win
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7880424
My bet is that a i3 clocked at same speed as a i5 or i7 will get very much the same results... :P
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7880440
Its debatable, when competing in HWBot competitions I find a lot of the time, i3's and i5's beat i7's single core score by a huge amount, so in some terms, its actually better to use an array of CPU's to get the best performance. That all depends on the game though!
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7880456
Thats a bit weird then.
Because a core i3 or a core i7 from the same family are pretty much the same thing core for core if they are clocked at the same speed.
A core i3 is basicly an i7 with 2 faulty physical cores disabled, and some cache disabled.
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7880502
DigitalFoundry did some tests on i5-2500k vs i7-3770k (and at the end of the video the 6700k), and the i7-3770k had around 10 more FPS in most of the games tested. They also tested the i5-2500k with faster RAM and even that gave ~5 FPS more. The i7-6700k had about 10 frames more than even the i7-3770k which is still a very capable card. Most modern games are taking advantage of more CPU cores, and even faster RAM. Without being able to test it, based on DF's results, I'd say you would actually see a decent improvement with an i7 > i5 > i3 in most titles.
Edit: EVEN BETTER! They did the test with the i3-6100 vs i5-6600k vs i7-6700k and it was pretty clearcut. Link to video:
https://linustechtips.com/topic/608800-will-my-cpu-bottleneck/#findComment-7880515
