HDD
TOSHIBA 1TB    50$
RAM
GSKILLS RIPJAWS X-RED 8GB                34.79$
Case
COOLER MASTER ELITE RC102 W/ 500W PSU           28.27$
MOTHERBOARD
MSI H81M-P33                    53.27$
GPU
PALIT GEFORCE GTX 750 TI 2GB DDR5 128BIT OC STORMX    119.59$
CPU
INTEL PENTIUM G3260 DUAL CORE   58.71$
Total     344.63$
How is it? is it safe to be using a PSU that comes with the case? when I picked the parts in pc part picker it says "Some Intel H81 chipset motherboards may need a BIOS update prior to using Haswell Refresh CPUs." what does this mean? is there any parts that I can improve i have a budget of 400$, and can it run the latest games like witcher 3, fallout 4, tomb raider, assassins creed syndicate and other games in the future on a 1600X900 monitor?
https://linustechtips.com/topic/608609-thoughts-on-my-build/
A BIOS update means you need to update the motherboard's firmware. However this usually requires a processor already compatible with it to work. If you want something that works out of the box, you'll need either a H97 or Z97 board unless you can find out that your motherboard can run the processor out of the box.
And it should run those games, just not very well even at that resolution. You're probably going to have to leave the details on at medium at best if you want to maintain a steady 30FPS.
EDIT: So a quick Google search tells me there's a good chance a lot of H81 boards are compatible out of the box. However, make sure whoever you order from has a good return policy in case you get a board that isn't compatible out of the box.
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876174
If you can't spend too much on your PC, then i would suggest looking at used parts.
I built my current PC from 90% used parts only bought the GPU PSU and hard drives new the rest was used. It came to around £280 (405$) for my i7 2600k, Asus P8P67 Motherboard, Corsair H100i cooler and 12GB of DDR3 RAM
So if you are not to afraid of buying used then you can score some real nice deals.
I see the GTX 780 go for like £150 (216$).
If you buy accordingly you could get a nice PC. You just need to make sure the seller has good feedback, and if something seems to good to be true then it porbs is.
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876200
if you can, definitely get some parts used.
CPU: AMD Athlon X4 845 3.5GHz Quad-Core Processor  ($59.98 @ NCIX US)
Motherboard: ASRock FM2A78M PRO3+ Micro ATX FM2+ Motherboard  ($51.98 @ Newegg)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR3-1600 Memory  ($24.99 @ Newegg)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($41.99 @ NCIX US)
Video Card: Zotac GeForce GTX 950 2GB Video Card  ($134.99 @ Micro Center)
Case: Rosewill SRM-01 MicroATX Mini Tower Case  ($27.99 @ Amazon)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($54.99 @ SuperBiiz)
Total: $396.91
Generated by PCPartPicker 2016-06-09 10:20 EDT-0400
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876230
http://pcpartpicker.com/list/JKk6hq
CPU: AMD A6-6400K 3.9GHz Dual-Core Processor  ($47.98 @ NCIX US)
Motherboard: MSI A68HM-E33 V2 Micro ATX FM2+ Motherboard  ($39.99 @ Micro Center)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory  ($29.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($22.99 @ Micro Center)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Newegg)
For the video card, wait for the rx 480, for about $200 you can get pretty good performance. And yes, I do agree that if you get second hand/ used parts will give you good performance. Since the GTX 10XX cards are comming out, many people are selling their old cards for cheap.
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876237
450$ with 16GBs of RAM and SSHD! :D
http://pcpartpicker.com/list/jvmgsJ
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876238
http://pcpartpicker.com/list/n8XvKZ
*Updated* Added quad-core CPU, however, I do belive that you can find a better used cpu on ebay or something.
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876249
1 minute ago, Cela1 said:
Please don't encourage him to get a dual core.
This, stutter city is no fun! :(
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876256
Thank you guys but I'm actually Living in the philippines so it's hard to buy things online, so what we do is go to the store directly, if you want guys I will attach the pricelist of the most famous computer hardware store in the philippines, I'm very happy that many people is willing to help me ^_^
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876269
Look for a Athlon X4 845 to 880K along with a FM2+ board and a R7 370 or GTX 950! :D
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876280
Yea, quad core at the lowest.
More and more games are using more cores now, and somes games won't even start on dual core CPUs.
And there will be a large spike in the used market as people are selling their old hardware.
I pesonally have my used GTX 760 2GB card for sale. I bought that used for £90 (130$)
The best I would say is this:
Case: New - That way you have all the parts you need to build in it.
CPU: Used (Same as MB)
MB: Used or New - Depends on price and what you can find
RAM: Used - Very Cheap normally
PSU: New - Would'nt risk a used one in case it dies
HDD: Prefer new but used can be very cheap and still have decent offerings.
Cooler (If needed): New or Used for a heatsink makes no differance.
GPU: Used - Can get some killer deals here. Used cards means you could get a better card than the one you plan on getting, but from an older generation.
That is how I would look at buying parts.
Mix Used with New.
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876283
2 minutes ago, Natsuha said:
Your budget in local currency?
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876285
Mix Used with New.
RAM should be 1866MHz CL9 unless it cost to much! :D
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876296
Don't get a gtx 700 series gpu, they are two generations behind now that Pascal is out.  Either get a used GPU or wait for Polaris which will be WAY faster than the gtx 750.  The RX 480 is $200, but they'll have cheaper ones too.  Might have to wait a month or two before they are available in your country.  If you can't wait, buy used parts.
Definitely try to get a name brand power supply with a bronze efficiency rating or better.  A cheap no name psu can end up killing your machine.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876340
Go with a quad core if at all possible.
Cpu:g3260 php 2690
Mobo:asus h81m-k/c/si php 2500
Graphics card:gigabyte r7 370 php 5570
Ram: kingston 8gb ddr3 1600 php1500
Hdd:western digital/seagate 1tb php 2540
Psu:fsp hexa+ 550w php 1900
Case:aerocool gt black/v3x black php 1650
Total: php 18350
Prices in bold are pc quarters, the rest are gilmore.
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7876407
13 minutes ago, Natsuha said:
Last question guys can the computer that herman built for me be upgradeable? I kinda want to put an i5 in the future and a new graphic cards.
yes, its upgradable, you can replace the pentium with an i5, and there should be enough space on the case to accept longer GPUs,
https://linustechtips.com/topic/608609-thoughts-on-my-build/#findComment-7879512
