inb4 someone starts to rant about how supposedly the i7 920 is still a much better option than the 6600k
/s
on topic: you will need different mounting hardware for it, if you held onto the mounting hardware it had in the box, look for the brackets for lga1155/1156/1150/1151 (they're all the same)
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7871114
Although this is a poor stock image, most after market CPU coolers will have extra positions on the bracket to support multiple CPU's of the same brand, cutting costs down by doing so, else the coolers would be far to expensive if they had to engineer multiple types (more than already out there anyway)
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7871249
so you think it will work?
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7871256
/s
i´m ready
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7871270
If you're using the SecuFirm2 mounting kit, you should be able to use the same hardware.
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7872111
28 minutes ago, IJarbo said:
I have no idea what that is... guess i will get a new cooler anyway so yeah.
Do you not know what cooler you have?
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7872251
4 minutes ago, cayphed said:
It's easy enough to forget, the PC world revolves around some seriously stupid model numbers, give the kid a moment to go home and check, then we'll try helping, yeah?
well then it's on him to google noctua, and secufirm 2 and see if he has that mount?
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7872370
1 minute ago, IJarbo said:
I could not find the model number, but it will take a  while until i can afford my upgrade so i guess i can see then later on. Thanks for trying to help me anyway (:
Can you post picture of cooler? We can help to identify it. Also, since you probably don't have receipt (to get free mounting kit), you can buy mounting hardware if its compatible. Its about €10 per kit.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7875270
yeah, i can do that in a couple of hours
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7875272
22 hours ago, IJarbo said:
so i looked on Noctuas website and i think that it is the NH-D14 and it seems like it is compatible with LGA 1151 without any extra mounting kit
Well, if its dual tower... yeah it will work.
https://linustechtips.com/topic/608112-cpu-cooler-socket/#findComment-7879893
