Hello guys! Welcome to my 5th project!
After the TwinForceTower I'm back with a new mod,Vector!
Short preview of the final result (I don't doubt the possibility to vary something!)
Config:
Case: Bitfenix Pandora ATX
Fan: 11x BitFenix Spectre 120 Led
PSU: Seasonic Prime 750W
CPU: i7 6700K
Motherboard: Z170A-GD43 PLUS
Ram: 32GB Transcend 2400Mhz DDR4
Ram Heatsink: Arctic RC PRO
VGA: GTX 970 Liquid Cooled
SSD: 2x Transcend SSD220S 240GB
Cable: BitFenix Alchemy Cable 2.0
Liquid cooling: Alphacool/Phobya
WB CPU: Alphacool NexXxoS XP³ Light
WB VGA: Alphacool NexXxoS GPX
Pump/Reseivor: Alphacool VPP755 PWM + 250ML Tank
Tubes: Alphacool Eisrohr 16/13mm plexi
Fittings: Alphacool chrome
Liquid: Mayhems Aurora Red + Yellow addictive
Radiators: Alphacool Eisbrecher Pro XT45 Full Copper 240 + Alphacool Eisbrecher Pro XT45 Full Copper 360
Peripheral:
Arctic P533 Headphones
Enjoy!
Facebook Page / Instagram Page / Modding ART Page
Projects:
PSPC (2013) > Kathrine (2014) > Cub8 (2015) >TwinForceTower (2015) > Vector (2016) > Etna Comics 7 #EC7 (2017) > Etna Comics 8 #EC8 (2018) > Yin Yang (2018 in progress)
https://linustechtips.com/topic/607723-project-vector-by-themitichris/
1 hour ago, Bigfootmandude said:
How do you plan on painting it with that pattern? Painters tape and spray paint?
I'm not sure yet, I think I'll do itbt  using different color films.
I'll keep you updated!
Projects:
BitFenix Pandora ATX
Projects:
Bitfenix Spectre 120 Led
Bitfenix Recon
Bitfenix Alchemy Cable 2.0
Projects:
Early stages, removal and ... start modding ;)
I'm starting to do the midplate and arrange with the structure that supports the bracket for I/O
Tell me what you think, your suggestions are always agree;)
Projects:
New Update, here is finally the components protagonists of this mod!
i7 6700K
MSI Z170A-GD43 PLUS
GTX 970 iCHILL, which, however, will be liquid cooled
am continuing to improve the quality of my photos, tell me what you think!
Projects:
  • 1 month later...
I'm finally back at work!
I finished the back panel making the necessary holes for the power supply and the front wall midplate.
Now I'm starting to make the support for the I/O grid
Projects:
On 4/8/2016 at 8:41 PM, TheCamba said:
Keep it up!
Yes sir!
New update!
Made the top plate and a preview of the position of the component
Projects:
On 15/8/2016 at 3:44 PM, TheCamba said:
Nice update.  Coming along smoothly?
Once a week ;)
Projects:
New updates, I made holes and brackets for the motherboard and video card, now they're well anchored! I've also placed the front radiator, I only have to fix the tank and give space to the ssd.
I also created a cover for I/O, all will be painted properly :D
As always, tell me what you think!
Projects:
New update!
Here are what the fans and the radiator after a close meet with the paint : D
Projects:
  • 1 month later...
New Sponsor!
Thank to Seasonic for this impressive Prime 750W Titanium!
Projects:
  • 1 month later...
New Update!
New sponsors: Alphacool & Phobya
Projects:
2 hours ago, Yahtadi said:
Im on board!
I will try to be more constant with the update!
Projects:
  • 1 month later...
We're arrive at the final steps!
Dismount and preparation to paint!
Projects:
  • 2 weeks later...
Painting and wrapping..
Projects:
New Sponsors! Thanks to Arctic & Mayhems!
Projects:
New Sponsor: Transcend (Happy to say: Again!)
Projects:
Time to mod...
Projects:
And the Headphone? Modded!
Projects:
17 hours ago, Alexokan said:
dude, spend some more time on the vinyl wrapping.
looks cheap with bubbles and jagged edges everywhere.
Unfortunately vinyl was not bubble-free so sticking continuous bubbles, for final photo I'll try to fix everything
Projects:
