Hey!
I will build a new computer but I don't know what case I sould get...
there is a lot of things you can want in a case and alot isn't that important but here is a list of things that would be cool to have:
highest price: 200$
-small but have support for a E-ATX motherboard formfactor.
-vertical graphiccard.
-side window.
-built in watercooling
-fancontrolling
https://linustechtips.com/topic/607248-help-me-find-a-good-case/
Just now, Darhagonable said:
silverstone raven rv03
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/607248-help-me-find-a-good-case/#findComment-7862451
smallest case i can think of that unofficially supports e-atx is the corsair c70
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/607248-help-me-find-a-good-case/#findComment-7862470
4 minutes ago, Darhagonable said:
maybe
what do you mean by unofficially? to make it work I would ghave to force it in or what?
It accepts some e-atx motherboards just doesn't say which on the site. But the c70 club should say which or answer any questions
http://www.overclock.net/t/1270969/official-corsair-vengeance-c70-gaming-case-owner-club
https://linustechtips.com/topic/607248-help-me-find-a-good-case/#findComment-7862502
NZXT noctis 450 and H440 unofficially support eATX
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/607248-help-me-find-a-good-case/#findComment-7862530
Why do you need E-ATX? Especially with pascal where you can link max. 2 GPU's in SLI, so it's even more useless... Or do you have any special plan for it? And according to your plan to use a vertical graphics card you won't be able to use a lot of pcie devices anyways...
That's actually a pretty easy mod, you just have to drill a hole and get one of these cheap pcie cables... So I wouldn't look for this and just do it myself if the case doesn't support it.
In the end if you go with my points I would recommend the NZXT Noctis 450. It has a window (which you can easily extend btw), good watercooling support (2x 360mm radiators), a built in fan controller and a nice psu cover. Also you can have a lot of space for hard drives (which I personally wouldn't need, but many people seem to have a ton of hard drives...)
https://linustechtips.com/topic/607248-help-me-find-a-good-case/#findComment-7872790
okey
that one is pretty cool...
can you check my last post? can you answer that question?
https://linustechtips.com/topic/607248-help-me-find-a-good-case/#findComment-7872881
btw I don't know if you're into modding, but this is a really cool build log in the Noctis 450, that I mentioned earlier: http://themodzoo.com/forum/index.php?/topic/2305-build-log-batgirl/&page=1
Some of these things may be extremely hard to do, but maybe just cutting out a bigger window and removing the hard drive cage might look really sexy with a watercooling setup :)
https://linustechtips.com/topic/607248-help-me-find-a-good-case/#findComment-7872967
