USB 3.0 Mouse Myth or Not
TymmVonD
Sorry if this has been posted, I searched to find No results.
I have been having an issue every once in a while with my 3 month old M65 and my USB 2.0 ports.
Once in every 10(?) reboots, my mouse recieves no power and doesn't respond. LEDs don't light.
So if I unplug then replug, the mouse instantly comes back to life. I had everything unplugged while removing molex pins to shorten the cable. Upon replugging everything, without any thought, I plugged in to a 3.0 port this time and forgot about it.
15 minutes later, boot up PC, get into Windows and my mouse feels different. Feels smooth like my pointer glides. Then I remember so...
Does 3.0 technically have an impact on mouse performance?!?! Or are my 2.0 ports so shot, I'm finally experiencing how my mouse was intended to operate?
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
Mouse doesn't need usb 3.0. same concept as why HDD doesn't need SATA III 6gb/s.
They get no noticeable performance increase because they simply can't use the extra oomph for anything.
Your USB 2.0 ports must just be whacked out.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
usb 3 supplies more higher amps i believe, theoretically faster battery charging for wireless mice?  would the mouse manufacturer need to plan for this?
I love more higher amps.
The USB device will only take as many amps as it is engineered to. The port won't force an overload.
