I recently restarted my computer, meaning i uninstalled everything using Windows Recovery. Now ever since i have no desktop, all i see in a black screen and my cursor works. I can cltr + alt + delete to go to task manager and thats about it. I cant go to Internet Explorer to download things, i cant to jack shit. Any help is appreciated, i have no clue what to do.
https://linustechtips.com/topic/606955-i-have-no-desktop/
check if explorer is running,if not
winkey+r and open explorer?
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859278
In task manager go File > Run new task and type in explorer.exe
If that doesn't bring everything up, kill all instances of explorer.exe and then try and run it again.
If it truly gone you'll probably have to do a repair via install media.
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859286
when i run the new task Windows Problem Reporting pops up for a little in Background processes but goes away
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859327
Usually if your explorer crashed, you can do Ctrl + Shift + Esc to open the task manager, then click run and write explorer.exe in the run window.
If that doesn't work I'd run a system file check - find the command propmt by clicking browse in the Run window, should be in the System32 folder. Then right click it and choose run as administrator, once the promt is up, write
sfc /scannow
and press enter to run a scan of your system files.
Also, once you get it up and running run a malware check, I've had malware crashing the explorer before.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859386
7 minutes ago, SCGazelle said:
can you login to an account? (I don't knw if you can control+alt+deltet) at that screen
6 minutes ago, SCGazelle said:
Also, do you have installation media? Like a copy of windows on a usb stick
i can logout, lock the screen, switch user and go to the task manager. i dont have an installation media and i dont think i can get one
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859388
sfc /scannow
im trying your second method right now hopefully it helps thanks
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859422
sfc /scannow
ok it finished and it says
"Windows Resource Protection did not find any Integrity violations"
could it be graphics drivers related?
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859453
I don't think so. Hmm.
So when you run the task "explorer.exe" it doesn't do anything?
Computer Specs:
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859458
2 minutes ago, wolfie495 said:
it pops up Windows Problem Reporting in the task manager for a couple of seconds thats it
Can you try and read what the report says?
Computer Specs:
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859473
all of a sudden my Razer Synapse just popped up, is that a good thing? lol
It is. But do try to recover the information on the explorer crash.
Also if you have antivirus, locate its folder in your files and click on any of the executables that are in there. Hopefully that'll bring up the antivirus interface and you can run a scan.
Computer Specs:
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859488
ok it looks like my hard drive that i thought i removed everything from had all my files in it, i think it just saved my computer and i probably can fix it now. thanks for the help im running avast right now
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859515
Awesome. When Synapse started running I wondered whether it was a drive issue. Cheers!
Computer Specs:
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859521
sorry to bother you again however i literally dont have a desktop, i ran avast but it didnt help. I guess during the installation process of windows it never downloaded the desktop lol. i can use google chome and i can download things now but i just cant use the desktop because i straight up dont have one
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859707
Is there a file in the C:\Windows folder called explorer.exe?
Computer Specs:
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859715
yea i see it
Try and double click it. Alternatively, right click it and run it as administrator.
Computer Specs:
https://linustechtips.com/topic/606955-i-have-no-desktop/#findComment-7859748
