2 minutes ago, TubsAlwaysWins said:
Ok so someone please explain freon cooling to me. Isn't it the same as phase change? If I were to set up a freon/phase change cooler what order would the loop need to be in? (condenser>res>GPU>RAD... etc.)
yeah its how your AC works in your car.
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
When the liquid freon flows (in its critical state) to the heat generating compontent in this case a CPU or GPU it evaporates quickly which inturn takes heat away from said component, it then travels back to the compressor before that it passes through a heatsink which cools it for ease of compression. It gets compressed back into a liquid and the whole cycle repeats.
CPU: R7 5800x -- Mobo: Gigabyte B550 Gaming X v2 -- RAM: 2x16GB Kingston Fury Renegade -- GPU: Asrock RX 6800 XT Phantom Gaming OC -- Case: Fractal Design North Walnut/Black Mesh -- Storage: 2TB 970 Evo Plus, 4TB NM790 -- PSU: BeQuiet Pure Power 11 Platinum 650w -- Displays: AOC AGON  AG352UCG, Dell Ultrasharp U2715H -- Cooling: Noctua NH-D14 -- Mouse: Corsair M65 -- Keyboard: Func KB 460 MX Blue -- Sound: Motu M2 -> THX 789 -> DT880 600Ω -- Mic: RØDE NT1-A
RIG 2: Intel i5-8400, 16 GB RAM, RTX 2070S
So I would go res> pump > GPU > CPU > RAD > compressor   right?
Breaking things 1 day at a time
Yeah pretty much although the CPU and GPU both need a loop
it can't be in series needs to parallel, I think
6 minutes ago, TubsAlwaysWins said:
So if I was to go and find a old condenser unit what else would I need?
Blocks that can withstand very low temps and alot of insulation
That would be more difficult than you anticipate, Fridges only go on for a couple of minutes at a time so you'd need parts that were rated for 24/7 for the cooler to not break down constantly. What you'd need is some kind of industrial one.
You'd also need to be something of a Physics buff to be able to do this and if you're only just learning how one of these systems works, I doubt you'll be successful in your endeavours (at least in the near future).
Why?
Because the freon has to evaporate to take the heat away when it passes over the CPU and evaporates you won't be able to run that to the GPU to get it to cool that. But as I said I'm not completely sure about that
For the physics side I don't know a ton, but I do have the internet and my dad to help me. He can usually figure stuff like that out
If I was to keep it at like a degree above room temperature....
The cold freon will always be at excess of -40C and even if it would be 1 degree C water will still condense and we all know what water does to electronics..
Ok. So I would need to go Res> pump > GPU > RAD > condenser > res > CPU?
Ok so basically I will be getting negative temps then
You can check out Linus' video above for a typical scenario and expected temps.  I would also advice you watch it to see what kind of prep is needed to do this safely, since jumping straight in without the right preparation will cause condensation all over the motherboard which will probably kill it.
Yeah. I would use some eraser stuff and neoprene
18 minutes ago, Ronnie76 said:
you need a fairly powerful condenser
@Jumper118 knows some things I believe
Owh @Jumper118 I summon thee!
@TubsAlwaysWins
Bit late but..
Not feasible.
You need to know how to get the gas level correct, oil correct, correct suction & discharge size and correct placement and size of u-traps.
Then you need a compressor capable of sustained load, suitable gas type (depending on target temp, crappy compressors like the one in Linus' video use R134a, cooler phase units will use gas like R507/R404a) and a condenser with enough capacity to dissipate the heat.
And then you also need a power solution.
I have 2 units, one is a little Danfos type LBP compressor which is around the 1/3hp mark and uses R404a. Tops out around -44c at evaporator without load. And with a quad core load at 1.55V it will go to around -30c. My other unit is a 3/4hp rotary style which is far more efficient as far as compressors go, and uses R407C and tops out around -59.5c. With quad core load at 1.55v it will do around -56.5c
you could pulse the cooling like fridges do based on cpu temps
