Cable Management Help
Go to solution Solved by MDH,
4 hours ago, NaLu said:
It will rather not work, just look at how narrow there is in the back. Probably enough space only to close the panel.
My idea is to put all the cables is 5.25" and HDD/SSD cages.
And use zipties.
A lot of them.
6 hours ago, GDRRiley said:
the cables to the back of the case
Well after about an hour of playing around with the cables I'm actually really happy with how it turned out. It's not perfect, but I think you'll agree it's definitely an improvement.
I've got a Thermaltake Chaser A21 and I've recently been told by a friend that my cable management is "disgusting", so I decided to have a look at what I can do with it but I'm completely clueless. There are no holes inside the case through to the back, as far as I can see so I don't know how else to route them.
Anyhelp would be greatly appreciated, thanks.
https://linustechtips.com/topic/606014-cable-management-help/
use zipies  to hold the in the back of the case
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/606014-cable-management-help/#findComment-7850102
1 minute ago, MDH said:
Hold what in the back of the case?
https://linustechtips.com/topic/606014-cable-management-help/#findComment-7850105
Oh, so zip tie them around the hard drive mounts at the back?
yes
https://linustechtips.com/topic/606014-cable-management-help/#findComment-7850110
My idea is to put all the cables is 5.25" and HDD/SDD cages.
And use zipties.
A lot of them.
Good thinking, I'm going to have a play around with it soon, so I'll see what works.
https://linustechtips.com/topic/606014-cable-management-help/#findComment-7850552
And use zipties.
A lot of them.
https://linustechtips.com/topic/606014-cable-management-help/#findComment-7851110
looks better. Nice work
https://linustechtips.com/topic/606014-cable-management-help/#findComment-7852276
