Hey so I built my first computer and have a wireless adapter right next to my gpu and gpu fan just wondering if it'll be fine (won't be in forever just till I move)
(Pictures below)
Also would love to hear opinions on how I did for my first pc build (Does it matter if all the cables are jammed in tight in the back panel?)
Sorry if this is in the wrong section and thanks in advance
https://linustechtips.com/topic/605952-will-this-work-opinions/
Cable MGMT isnt the best. (My eyes hurt from that cable zip tied to the drive cage)
The graphics card should work fine nestled next to the wireless adapter.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/605952-will-this-work-opinions/#findComment-7849631
Ya I realize the cable management isn't the best but it was the best I could do (case wasn't to good) but do you think it's could enough for good air flow
https://linustechtips.com/topic/605952-will-this-work-opinions/#findComment-7849655
make a wooden brace to prop up the GPU. I am using one right now that I made
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/605952-will-this-work-opinions/#findComment-7849658
It seems good enough for airflow but not for looks. I'm hoping you have a non-glass side panel.
Desktop
LAPTOP
https://linustechtips.com/topic/605952-will-this-work-opinions/#findComment-7849661
It'll work fine. I've never personally known a wireless card to thermal throttle which would be my only possible worry when next to a GPU.
https://linustechtips.com/topic/605952-will-this-work-opinions/#findComment-7849663
or fishing line. or something like:
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/605952-will-this-work-opinions/#findComment-7849682
