So I have the paid version of firestrike and im having some issues. Before firestrike just worked, but now it says I need to install each of the tests I want to run. Whenever I click install it goes to 0% and then quits. Please help
It works
Breaking things 1 day at a time
https://linustechtips.com/topic/605925-firestrike-issues/
Its actually installing it just doesn't tell you. I had the same problem and after 5 min it just worked.
although firestrike can't detect system info on windows server 2012 R2... So I can't run it anyways :(
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/605925-firestrike-issues/#findComment-7849341
Yeah I figured that out
https://linustechtips.com/topic/605925-firestrike-issues/#findComment-7849626
