HTML Help
Go to solution Solved by Guest,
6 minutes ago, KuJoe said:
Just ignore my code completely if you're planning on using tables, my code will only work if you're just looking at displaying 3 images next to each other with each one equal of width (except you can't divide 100 by 3 equally so one of them will be 34% while the other 2 are 33%).
Here's what I used:
<table width="100%" align="center">
	<tr>
		<td width="33%"><img src="whateveryouwant.jpg" width="100%"></td>
	</tr>
</table>
I am currently coding a website for a school project. I have 3 images in a table (1 cell each) and the table stretches to 100% of the page. How do I get it so that the images will always stretch to 1/3 of the table (while still maintaining aspect ratio)
https://linustechtips.com/topic/605912-html-help/
I wouldent use a table, tables are nooot good for responsiveness. Use divs.
https://linustechtips.com/topic/605912-html-help/#findComment-7849183
5 minutes ago, GoodBytes said:
Post your code.
But you can set the width and height of an image to a percentage.
my code looks a little something like this:
  <tr>
    <td><img src="picture1.png"></td>
    <td><img src="picture2.png"></td>
    <td><img src="picture3.png"></td>
  </tr>
</table>
https://linustechtips.com/topic/605912-html-help/#findComment-7849202
Something like this?
<div style="width:33%;float:left;border:1px solid black;"><img src="image1.ext"></div>
<div style="width:34%;float:left;border:1px solid black;"><img src="image2.ext"></div>
<div style="width:33%;float:left;border:1px solid black;"><img src="image3.ext"></div>
-KuJoe
https://linustechtips.com/topic/605912-html-help/#findComment-7849206
<div style="width:33%;float:left;border:1px solid black;"><img src="image2.ext"></div>
would that work?...let me try
https://linustechtips.com/topic/605912-html-help/#findComment-7849209
Just keep in mind that I'll use divs within the table cells....just easier to keep things neater :P
https://linustechtips.com/topic/605912-html-help/#findComment-7849211
-KuJoe
https://linustechtips.com/topic/605912-html-help/#findComment-7849237
Here's what I used:
	<tr>
	</tr>
</table>
https://linustechtips.com/topic/605912-html-help/#findComment-7849256
