at least one more 360mm rad, but that'll be close. 120mm for each component min. I guess you'll have a 360 rad atm. jayztwocents has a 480 or 560 + a 240/280 for 3 titan x's
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/605198-water-loop-upgrade/#findComment-7841694
3 minutes ago, Cerunnos917 said:
i was thinking of a 4x120 and a 1x120 on the intake fan. Would this be overkill?
nope. I guess that would work fine
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/605198-water-loop-upgrade/#findComment-7841696
