1. Budget & Location
the aim is not the budget, the aim is that it does what i need for the least. then i will spare up to the point where I can afford it and buy it, i dont have price in mind, i have expectation in mind
currency: Canadian Dollar (CAD)
if you're using pc part picker, in top right corner you can swap to canadian currency.
2. Aim
latest games (watch dogs 2, the divison, far cry, witcher 3 and alike) 1080p stable 60FPS on high preset (no need for more)
then basic internet browsing, video watching
3. Monitors
single 1080p 60FPS with g-sync/freesync depending on which graphics card you get
4. Peripherals
nothing, i own keyboard/mouse and will get monitor
5. Why are you upgrading?
because laptop is too old to play "cool" games
RX 480 comes out pretty soonish, but id like already know what the whereabouts to price is, RX 480 costs about 200 usd, if your build plans, on me implementing RX 480 inside, add custom part worth 280 CAD.
technically i need it to do what is written in "2. Aim", scaled with price downwards.
https://linustechtips.com/topic/605172-60fps-1080p-build/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($254.98 @ DirectCanada)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($52.00 @ Vuugo)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  ($34.56 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($62.90 @ Vuugo)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($57.40 @ DirectCanada)
Power Supply: Cooler Master 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($67.99 @ NCIX)
Monitor: ViewSonic VX2257-MHD 21.5" 60Hz Monitor  ($173.50 @ Vuugo)
Other: rx 480?? ($280.00)
Total: $983.33
Generated by PCPartPicker 2016-06-02 12:58 EDT-0400
The monitor is freesync?
https://linustechtips.com/topic/605172-60fps-1080p-build/#findComment-7841269
Total: $983.33
are you sure 8gb is enough for the latest games? werent there games that needed more than 8gb? not to mention operating system itself
https://linustechtips.com/topic/605172-60fps-1080p-build/#findComment-7841418
