Hi just wanted some help choosing a good budget graphics card for a prebuilt system. I was thinking of the gtx 750 ti 2gb gddr5 since it has good benchmarks and and a nice price but I feel a little unsure if my system has decent compatibility with the card. BTW I am totally new to the upgrading PC world and I want to start by upgrading this system to a decent gaming pc for my younger brother. Here are the system specs:
  • CPU: dual-core i3 2100 3.10GHz
  • Graphics Card: geforce 8400gs
  • PSU: 600W
  • 4gb ddr3 ram
  • Mainboard Model (just in case): DH67BL
Thanks to anyone who answers this!
https://linustechtips.com/topic/604354-help-choosing-a-graphics-card/
Just now, Mauri_JHN said:
It seems pretty good but unfortunately my budget is $110, but do you think the RX 480 will work in my system?
That would be about $100 over budget though. As long as your case is big enough, you definitely have enough power for it. If you want to stay near budget, I would pick up a GTX 950 and another 4GB stick of RAM. That should run you about $140-150 if you are in America.
My legit rig:
CPU: i5 6600k GPU: Asus Strix 1070 RAM: 16 GB of Corsair LPX CPU Cooler: NZXT Kraken X61 Motherboard:  Asus Z170I Pro Gaming Storage: Adata Sp550 120 GB and WD Black 3 TB Case: NZXT Manta Power Supply: EVGA 550 GS Monitors: 2 LG 25UM58-P Ultrawides Keyboard: Cooler Master Quickfire Rapid-i Mouse: Logitech G502 RGB
will the shortage in ram affect significantly in gaming performance?
Lol, I accidentally added your post as informative. In any case, I watched a video reviewing the difference between 4, 8, and 16gb of RAM for gaming. Basically, their will be a fair bit of stuttering and sudden frame drops if you plan on having good graphics during gameplay. 8 is recommended. You could totally survive with 4 for awhile though.
My legit rig:
Thats for supported games, but games like Star Citizen between others wont even run.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
3 minutes ago, Mauri_JHN said:
would it be good if I go with a 750 ti and 4 extra gigs of ram?
Humm.. Its an option, but im sure our general recommendation would be to save up a bit more. Trust me, its worth it. 480/1060, (we'll have to wait for benchmarks and such) + 4GB of ram will make a HUGE difference.
