C++ help run again
Go to solution Solved by Nineshadow,
12 minutes ago, derrickd241 said:
and here's the whole program if that helps
No because when I run this sure the run again displays but it displays one client in the array and it needs to loop main again so it will print them all at the same time then ask run again? then it will print them all at once again, so no this is the same problem I was having before
I didn't really understand tbh, but is this what you're looking for?
int main()
    bool	moreInput = false;
    do
    string  input = "";
    priority_queue<Client, vector<Client>, CompareClients> pq;
    Client clientArray[5] =
        { "John",	"Doe",	"719 444-5555" },
        { "Mary",	"Doe",	"719 444-5556" },
        { "Hari",	"Keri", "719 555-4444" },
        { "Mari",	"Mee",	"719 555-4445" },
        { "John",	"Doe",	"719 444-5557" }
    for(Client i : clientArray)
        pq.push(i);
        while (!pq.empty())
            Client c2 = pq.top();
            cout << "The Client being Popped = " <<
                 setw(10) << left << c2.fName << " " <<
                 setw(10) << left << c2.lName << " " <<
                 setw(14) << left << c2.areaCode << " " <<
                 setw(14) << left << c2.prefix << " " <<
                 setw(14) << left << c2.suffix << " " << endl;
            pq.pop();
        moreInput = runAgain();
    while (moreInput);
So, part of my assignment is to incorporate the runagain function into this program that takes an array and converts it to a vector so you can compare them and modify the order for which the array prints to the screen  most of the code is from my teacher but modified lol this is what i have so far but when I put while(moreInput); anywhere to loop it I get a syntax error
void main()
        string  input = "";
        // create an STL queue named pq - and use the STL priority_queue adapter
        // use the struct Client (that you created above) as your data type
        // use a vector of Clients for your Queue - to hold your Clients
        // then use the CompareClients (above) for comparison criterion
        // Create and Initialize an Array of 5 Client objects:
        Client clientArray[5] = {
        // Convert clients Array into a Vector in order to create an Iterator
        vector<Client> clients(begin(clientArray), end(clientArray));
        // create an iterator for the clients Vector named clientItr
        vector<Client>::iterator clientItr;
        // load each Client from the clients Vector into your Priority Queue using the Iterator
        // Your Priority Queue will use your comparison criterion to sort by last then first names
        for (clientItr = clients.begin(); clientItr != clients.end(); clientItr++)
            pq.push(*clientItr);
        // get the Top element of the Priority Queue and print it out
        // then pop (or dequeue) that Client out of the Queue
        while (!pq.empty())
            pq.pop();
} while (moreInput);
bool runAgain()
    string answer = "";
    cout << "Do you want to run the program again? (y/n): ";
    cin >> answer;
    cout << endl << endl;
    return ((answer[0] != 'n') && (answer[0] != 'N'));
https://linustechtips.com/topic/604254-c-help-run-again/
https://linustechtips.com/topic/604254-c-help-run-again/#findComment-7830439
// CS115-WK-09-WORKSHOP.cpp
// uses the Standard Template Library (STL)
// includes the STL Queue
// uses a priority adapter for the queue
// the queue expects to contain data type <struct Client>
// the queue will maintain a vector of Client structs
// the queue will use CompareClient overloaded operator ()
// CompareClient will return true if less-than
#include "stdafx.h"
#include <iomanip>
#include <iterator>
#include <iostream>
#include <string>
#include <queue>
using namespace std;
struct Client
	string	fName;
	string	lName;
	string  areaCode;
	string  prefix;
	string  suffix;
class CompareClients
public:
	bool operator()(Client& c1, Client& c2)
		// if last name is less-than - insert before
		if (c1.lName.compare(c2.lName) < 0) // less-than
			return false;
		// if last name is greater-than - insert after
		else if (c1.lName.compare(c2.lName) > 0) // greater-than
			return true;
		// if last name is the same and first name is less-than - insert before
		else if ((c1.lName.compare(c2.lName) == 0) && (c1.fName.compare(c2.fName) < 0))
			return false;
		// if last name is the same and first name is greater-than - insert after
		else if ((c1.lName.compare(c2.lName) == 0) && (c1.fName.compare(c2.fName) > 0))
			return true;
		else if (c1.suffix.compare(c2.suffix) < 0)
			return false;
		else if (c1.suffix.compare(c2.suffix) > 0)
			return true;
		else if (c1.prefix.compare(c2.prefix) < 0)
			return false;
		else if (c1.prefix.compare(c2.prefix) > 0)
			return true;
		else if (c1.areaCode.compare(c2.areaCode) < 0)
			return false;
		else if (c1.areaCode.compare(c2.areaCode) > 0)
			return true;
		else
			return false;
void main()
		string  input = "";
		while (!pq.empty())
			pq.pop();
bool runAgain()
	string answer = "";
	cin >> answer;
https://linustechtips.com/topic/604254-c-help-run-again/#findComment-7830537
#include <bits/stdc++.h>
struct Client
    string	fName;
    string	lName;
    string  areaCode;
    string  prefix;
    string  suffix;
public:
            return false;
            return true;
            return false;
            return true;
            return false;
            return true;
            return false;
            return true;
            return false;
            return true;
        else
            return false;
bool runAgain()
    string answer = "";
    cin >> answer;
int main()
    string  input = "";
    do
        while (!pq.empty())
            pq.pop();
    while (moreInput);
Like this?
Although I don't get why you don't just do this :
        pq.push(i);
https://linustechtips.com/topic/604254-c-help-run-again/#findComment-7830565
struct Client
    string	fName;
    string	lName;
    string  areaCode;
    string  prefix;
    string  suffix;
public:
            return false;
            return true;
            return false;
            return true;
            return false;
            return true;
            return false;
            return true;
            return false;
            return true;
        else
            return false;
bool runAgain()
    string answer = "";
    cin >> answer;
int main()
    string  input = "";
    do
        while (!pq.empty())
            pq.pop();
    while (moreInput);
Like this?
        pq.push(i);
#include "stdafx.h"
#include <iomanip>
#include <iterator>
#include <iostream>
#include <string>
#include <queue>
struct Client
	string	fName;
	string	lName;
	string  areaCode;
	string  prefix;
	string  suffix;
public:
			return false;
			return true;
			return false;
			return true;
			return false;
			return true;
			return false;
			return true;
			return false;
			return true;
		else
			return false;
void main()
		string  input = "";
		while (!pq.empty())
			pq.pop();
bool runAgain()
	string answer = "";
	cin >> answer;
https://linustechtips.com/topic/604254-c-help-run-again/#findComment-7830661
int main()
    do
    string  input = "";
        pq.push(i);
        while (!pq.empty())
            pq.pop();
    while (moreInput);
https://linustechtips.com/topic/604254-c-help-run-again/#findComment-7830705
int main()
    do
    string  input = "";
        pq.push(i);
        while (!pq.empty())
            pq.pop();
    while (moreInput);
you're a beast lol thank you very much works flawlessly now :) although I didn't use some of your code at least the run again works now lol
https://linustechtips.com/topic/604254-c-help-run-again/#findComment-7831037
